Old 03-11-2003, 08:09 PM
petesvx2's Avatar
petesvx2 petesvx2 is offline
02 sensors
Well, i got my right 02 sensor replaced, idle is smooth now at around 600 rpms, and running smoothly...so far so good
1992 Pearlie ... ??????k Sold 8/04
Kenwood KDC-MPV619
Wedgie Cupholder
1998 Acura Integra LS 74k Sold 1/07
2007 Toyota Tacoma Prerunner SR5 .04k!
2011 Toyota Tacoma Double Cab, 4x4 TRD Sport
Old 03-12-2003, 07:22 AM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
pete what hapened did u replace due to a c/e code or somethign else, elaborate
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
Old 03-12-2003, 09:15 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: 02 sensors
I still haven't gotten mine changed yet. Finally had some good weather this weekend, but, I had a basketball game to watch. Also, asked the wife to pick up an O2 sensor socket for me at the local auto parts store. I even wrote it down for her (O2 Sensor Socket, 1/2 inch drive). She wound up piddling 'round in town 'til after dark, so, I couldn't do the deed. Oh well. To top it off, she pointed to the kitchen table this morning and said, "There's the thing you asked me to get." I pick it up and look at it -- Great, now I can FINALLY get my sensors changed. Then, I noticed the size of the drive. 3/8. I asked her what happened. She said, I gave the guy at the parts store, your note. I told her to take it back, exchange it for a 1/2 drive, and to tell them that if they couldn't tell the difference, we won't be shopping there any more. Maybe this weekend.
Randy Johnson
Mike Davis -- at Reading VI
Old 03-12-2003, 10:44 AM
sfsvx's Avatar
sfsvx sfsvx is offline
Yeah, it's a poodle - so what?
By the way . . .
I've looked and can't find anything - are there any how-tos on replacing the O2 and knock sensors?
TIA.
Dick
1999 Legacy GT 30th Anniversary Edition
2001 Outback Sport
Old 03-12-2003, 11:19 AM
Aredubjay's Avatar
Re: By the way . . .
TIA.
None that I'm aware of.
The O2's are fairly striaghtforward. In the manual, the only suggestion (outside of removing and replacement), is the suggestion to spray the sensor with XX-number (special Subaru number for the equivalent of "Liquid Wrench" I suppose), and wait five minutes before trying to remove them, to avoid harming the threads or damaging the pipe. All manufacturers, of course, warn against using anything silicone based on or near the sensor.
Dunno 'bout the knock sensors.
Randy Johnson
Old 03-12-2003, 06:36 PM
drivemusicnow's Avatar
Poor College Racer
ok, my bank one sensor 2 O2 sensor needs to be replaced, says the check engine light, and although i don't think it actually does anything, i'm going to do it. Whats the cheapest i could get an O2 sensor, and are there any specific tricks to do the back one? keep in mind that I'd probably be doing this when the car is on jackstands, rather than on a lift. thanks for any input.
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 03-12-2003, 06:49 PM
lee lee is offline
Don't know any tricks (haven't done it myself - yet).
To add to what Aredubjay put down, here's what my CD on the SVX has to say:
Oxygen Sensor: Service and Repair
REMOVAL
NOTE: Do not apply excessive force to sensor when removing, especially when engine is cold. Permanent damage to the exhaust pipe may result.
1. Disconnect oxygen sensor electrical connector.
2. Apply a penetrating oil to the sensor base and allow to stand for one minute.
3. Loosen sensor 10° to 40° with a suitable tool (Subaru #499990110).
4. Again, apply a penetrating oil to the sensor base and allow to stand for one minute.
5. Remove sensor from vehicle.
INSTALLATION
1. Being careful to protect the sensor tip, apply a suitable high-temp anti-seize compound to the threaded portion of the oxygen sensor.
2. Thread sensor into exhaust pipe by hand as far as it will go.
3. Using a suitable socket, torque sensor to 18 - 25 ft.lbs (25 - 34 Nm).
4. Reconnect and secure oxygen sensor electrical connector.
Old 03-12-2003, 07:56 PM
petesvx2's Avatar
I was having c/e light issues so i brought it to my mechanic...it was the right 02 sensor causing the problem. Idle is still lower than i remember (i am dumb though so who knows) but it doesnt skip around anymore. it was kind of pricey though but i dont know how much it was supposed to cost so w/e. it was like 170 USD for the sensor and another 170 for labor, i did think it was aquick and easy job
Kenwood KDC-MPV619
Wedgie Cupholder
Old 03-12-2003, 09:30 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
BxS2 sensors are only on OBDII cars. Their reason for being is to monitor catalytic convertor efficiency. Just because the computer spit out a code for the sensor doesn't necessarily mean that it's defective. You could have a bad cat or any of a hundred other things wrong.
I'm beginning to love Autozone more and more each day. For the past several months I've been getting quite a bit of work from them. People go there for a free scan, they tell them "P0401 - Insufficient EGR flow" or whatever and sell them a part. First off, they usually sell them a crappy part that isn't worth owning. Then the customer finds out that that wasn't the problem. Then they bring it to me to fix. I get fix the car plus replace the new crappy part with a good one. Kinda like doubles my income...
BTW, I don't own an O2 socket or wrench. Are they really necessary? If you're going to cut the plug off anyway, why not do that first then just use a boxed-end wrench? I know, I know. If it wasn't for needing the right socket you'd miss the games.
Gee, if anyone else wants their sensor replaced come see me. I'll even knock $20 off that $170 labor charge. (hmmm....2 sensors @ $150/ea. x 20 minutes = $900/hr.) Yeah, that's right. I'll do them for that!
Old 03-13-2003, 08:55 AM
uh....thanks, BEAV.
how difficult is it to get to the connectors? are they close to the O2 sensor, or buried and hard to get to? lucky me, i have three!
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 03-13-2003, 09:03 AM
Aredubjay's Avatar
Originally posted by Landshark
uh....thanks, BEAV.
They're easy to get to (the first two, don't know about the third -- I only have two -- but suspect all are easy to get to, especially with the car on ramps). I think on yours, there will be one on each "Y" pipe, and another just before the converter where the Y goes into a single. Just a guess.
The least expesive O2 sensor I found was here:
http://oxygensensors.com/
They have them available with the connector, or without. Depends on if you wanna go to the trouble of cutting off the connector and doing a splice, or not.
Randy Johnson
Old 03-13-2003, 09:51 AM
sfsvx's Avatar
Wow - $65 for OEM equivalent, $40 for generic. Beats the bejesus out of $170.
I've been mulling over what I'd do for $900/hour. It ain't pretty.
Dick
2001 Outback Sport
Old 03-13-2003, 10:27 AM
Aredubjay's Avatar
Dick,
Hopefully, I can give you first hand knowledge about the change and the performance of these sensors. I plan to replace mine this weekend (I planned on it last weekend, but, it didn't happen). Notice that these sensors are GUARANTEED to perform like OEM for 100K miles. Keep your receipt.
And, Beav, the only reason I wanted an O2 sensor socket was to be able to torque the sensors to the specified 35 ft. lbs. Call me anal.
Randy Johnson
Old 03-13-2003, 11:01 AM
sfsvx's Avatar
Dick,
Thanks!
And . . . okay, you're - oh, never mind.
Dick
2001 Outback Sport
Old 03-13-2003, 11:56 AM
thanks, Randy.
BTW, does anybody know what's different about the rear "3rd" O2 sensor? i'm pretty sure its a different part# than the other two. different connector?
