Old 11-06-2002, 05:05 PM
Ticallion
I've had it with this suspension clunk!!
Alright, I've listend carefully and the clunk is prominent in two places
1) potholes - clunk in front driver side suspension
2) speed bumps - styrofoam rubbing sound from rear suspension
3) taking speed bumps diagonally - clunk from the driver side of the car, no matter which tire is taking the bump.
SOOOO... i'm thinking that the bushings are worn out. I'll just save myself the trouble and replace the ones that could be affected. Could someone make me a list of part numbers, and possibly a diagram where they're located? I'll pick up the parts tomorrow
THANKS!!!
-Ross
Old 11-06-2002, 05:23 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Give someone a fish and they'll eat for a day, teach them to fish and they'll eat for life
Start Here
http://www.subaruparts.com/diag/?model=2
Chose your year/model
Select Suspension, Axle and Brake
Select Front Suspension
Add your bushings to the cart,
Go back and select Rear Suspension (1)
Go back and select Rear Suspension (2)
After all parts are added, you can view the cart, print it out and you will have your list of parts to buy from whoever you like.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 11-06-2002, 06:43 PM
Ticallion
Thanks!!
Are there bushings in the control arm too?
Old 11-06-2002, 07:57 PM
mohrds's Avatar
Originally posted by Ticallion
Thanks!!
I'd have to go look at the car when its light out, I don't know off the top of my head.
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 11-29-2002, 09:58 PM
Ticallion
CLLLLLUNNNNNNNNNK ISSSSSSS GONNNNNNNNNNNEEEE!!!!%!#%*()!#()*^()*!#^()*!#)*(^* ()!#()*^()*!#^
After 15 seconds under the hood tightening the center nut, the clunk is GONE!!!
I checked the three nuts before, but i never bothered checking the center nut. It was a full three turns loose.
After a quote from subaru for $933 in parts, and $300 in labour (LMFAO), it was solved for NO money WHATSOEVER!!^%@!#!#^!#^!#^!#^
YAAAAAAAAAAAAAAAAAAAAAAAA!!!!!
Assholes didnt even open the rubber lid for the strut. They would have seen it right away.
Old 11-29-2002, 11:31 PM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
YOU DAH MAN!!!!
I read your post and RAN out to my garage to check. Bingo, same for me. The car is 100% more enjoyable to drive now.
Thanks a ton doesn't begin to show my appreciation.
Stephen
92 Ebony - Level 10/n2o REAR-ENDED
92 Teal - painted yellow/4.11 5spd/n2o SOLD
92 Claret - 4.44 SOLD
94 Barcelona - FWD SOLD
92 Ebony - 3.90 SOLD
94 Laguna ROLLING w/4.44s/Ecutune ECU +TCU/STI springs/Infiniti M45 rims
Old 11-30-2002, 12:47 AM
KUL RIDE
I'm sorry, but
what is the center nut???
Old 11-30-2002, 08:28 AM
Ticallion
Re: I'm sorry, but
Under your hood, pop the "d-shaped" plastic cover on the strut tower, then underneath that you will see a little rubber grommet covering the center nut. You can remove that with your fingers, and you will see the center nut.
Old 11-30-2002, 08:29 AM
Ticallion
Re: YOU DAH MAN!!!!
Stephen
Anytime Stephen!!! Better than the $933 parts and $300 labour subaru offered me. Now i have to go down there and request my money back for the useless quote.
Old 12-01-2002, 05:10 PM
amuse
ruibber grommet
Is this rubber grommet about the size of a CD? Will it go back into place after removing it?
Just wanna make sure I don't accidentally ruin anyhing
Thanks,
Pete.
Old 12-01-2002, 10:58 PM
elninoalex's Avatar
Registered Abuser
No, it is more like the size of a quarter. It will just pop off and on no problem.
Old 12-01-2002, 11:55 PM
Boone
Hmm... novel idea. Your struts are clunking and you tighten them up.
Old 12-02-2002, 01:06 AM
amuse
pic?
Any chance of a picture? I'm stumped... I take of the "D shape" cap, and underneath I find 3 bolts (in a triangle layout), in the middle is a big rubber surface... about half or greater the size of a CD).
Thanks,
Pete.
maybe I'm way off?
Old 12-02-2002, 12:34 PM
cjoffe
Re: pic?
Thanks,
Pete.
maybe I'm way off?
There should be a rubber grommet in the center. Pry it up and you will see the nut in the center.
I haven't checked mine yet... Will do tonight!
CJ
Old 12-03-2002, 10:13 AM
Ticallion
TTT just cuz i'm so goddamn happy there's no more clunk
