Old 01-14-2015, 08:24 PM
Gamesy's Avatar
Gamesy Gamesy is offline
hitch diagram
were the plans for the hitch ever loaded into the how to docs? i can find em.
Old 01-14-2015, 09:18 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
Re: hitch diagram
There are some pictures in the old lockers of Tuzem and Connsvx
There were sketches in somebody's locker, but I can't recall now. I may have saved them. If I find them I'll link it.
'20 Honda Ridgeline
http://www.x35design.com
Old 01-15-2015, 05:29 AM
Re: hitch diagram
Hitch is very simple. Basically it is a square bar connected between the rear tow rings, and a flat plate aprox 4"wide 1/8 thick bent to go under the gas tank and connect to the rear of the swing arm. I made a moc up out of cardboard and then tran to steel.
I will see if I can locate info.
Good shot of the pate connected to the rear of the swing arm plate
Parts laid out on the floor. Tricky part is the plate that attaches to the rear end seen front facing
Here is same picture. You can see the attaching plate welded to it
Hope it helps. I have towed 2,000 lb with it
