Old 02-11-2014, 08:17 AM
Your opinion
Saw this
Snake oil
The real deal
Not cheap....
https://steelseal.com/?utm_source=bi...Bing+-+JumpFly
Old 02-11-2014, 08:50 AM
Re: Your opinion
Assuming this fixes the head gaskets, what will you do with the distorted surfaces of our engine?
I don't see how this works especially that both surfaces on each side in the EG33 need actual machining.
Have you seen the vids of my engine resurfacing?
Old 02-11-2014, 10:04 AM
Re: Your opinion
Just another product that is a bandaid and will force you to need a complete block assembly once the bandaid falls off after a short while.
Old 02-11-2014, 10:22 AM
Re: Your opinion
i have rebuilt motors where the customer has tried products like this and the inside of the motor always looks terrible. if you could isolate it to the gasket area it might work but it coats your entire cooling system (and sometimes oiling system) of which the small leak area of the head gasket is a tiny percentage of the surface area. they usually end up with a rebuild, and new radiator and heater core when they could have just fixed the headgasket.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 02-12-2014, 05:25 AM
Re: Your opinion
Thanks! Just what I was thinking too. I also noticed that all the antifreeze people have stopped adding the stop leak to the product. I heard that it was sealing everything. Even stuff that should not be. . Always wondered how it would know what needed sealing
BTW I was not asking about it because I needed it. I just saw it in an add.
Old 02-12-2014, 09:03 AM
NiftySVX NiftySVX is offline
Re: Your opinion
Both these guys are right. Please do not add coolant additives. You do not want to put a heater core in an SVX. In more than ten years experience as a technician, I have only seen this stuff temporarily repair a very small radiator or heater core leak TEMPORARILY. However, it required replacement of both heater core and radiator on each car, and the water pump. Once it is in the system you can't get it out.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
