Old 01-20-2013, 11:03 PM
FM977 FM977 is offline
Exhaust-like smell coming through heater vents
I seem to have a rather unpleasant smell coming through the heater vents that almost smells like exhaust. It doesn't really smell like burning fluid (neither oil nor ATF). Has anyone here experienced this and determined the cause? I don't hear any exhaust issues other than the resonator which buzzes a bit
Thanks
Old 01-21-2013, 06:31 AM
Re: Exhaust-like smell coming through heater vents
If it is sweet smelling it could be the heater core leaking or a hose. Get a battery powered home CO alarm and put it on the front seat. That will tell you if it is exhaust or not
Old 01-21-2013, 06:37 AM
If it is the heater core leaking, your windshield will fog over if you turn on the defrost before the engine heats up.
Old 01-21-2013, 09:12 AM
That's a good idea! I'll try it and post back.
Old 01-21-2013, 09:57 AM
Huskymaniac's Avatar
Uses the ignore feature
Power steering leaks have been a persistent PITA for me and that smell comes in through the vents. If you see drips under the car, put paper towels under there and look at the color of what drips.
Tony
Old 01-21-2013, 11:57 PM
There may be a slight ATF drip from the PS pump, but it sure smells like exhaust.
Old 01-22-2013, 06:30 AM
Exhaust flowing into the coolant may be the sign of a heat gasket issue.
If you smell the coolant reservoir under the hood, does it smell of exhaust?
How many miles on the engine?
A quick test to see if your getting combustion gasses in your coolant via a head gasket: Smell the coolant. If its bubbling into the overflow tank, give it a sniff as well as when its cold pop the cap on the radiator and do the same. If it smells like exhaust or gasoline, then regretfully you have a bad head gasket. This will lead to your radiator blowing all of its coolant into the overflow tank in a short time, like a few days.
Pop the cap when your car is cold and see if the radiator is loosing a lot of coolant. Its a tell-tale sign.
