Old 01-03-2013, 11:43 PM
Blue94 Blue94 is offline
Okay, What Did I do? Strut Replacment
Hi Guys, quick question. I has some clunking noise coming from my struts so I bought new ones through Subaru parts and replaced them. The clunking noise is gone but I now I have a new noise. When I turn hard right I get a grinding noise, almost like the tire is rubbing. I took it in to get an alignment and they said everything looked good. Any ideas? When I search for possible reasons I get that I need to replace the struts. Well, check. Anything else?
Thanks.
FWIW, My struts were dated April of 2012. I know there has been some conversation on this, but mine appeared to be new.
Dust
Old 01-04-2013, 08:48 AM
SoobCrazy SoobCrazy is offline
SVX n00b
Re: Okay, What Did I do? Strut Replacment
Wheel bearings? That was the problem on a friend's bugeye wagon. Made a horrible creaking sound when the wheel was cranked at low speeds.
Old 01-04-2013, 11:48 AM
kwren's Avatar
kwren kwren is offline
May be associated with the drive shaft?
Keith
Old 01-06-2013, 04:15 PM
Ya, I'm definitely thinking that it is the drive shaft. I just received me new end links today, tomorrow I will get back under there and take a closer look. I'm wondering if the axle came out of the spindle just enough to cause tension on the CV? We'll see.
Thanks for the responses
Dust
Old 01-06-2013, 04:19 PM
Grinding noise or scraping noise? When I got it, my blue car made a scraping noise when turning that turned out to be the dust shield getting pushed against the brake rotor by the tie rod.
Old 01-13-2013, 09:07 AM
alia176 alia176 is offline
Dust
I've had something similar happen to me when I worked on a Forester front strut replacement. One one side, the half shaft came out of the front diff by about 3/8" and this caused a constant grinding type sound. It sounds like you maybe on the right track. Lift up the front of the vehicle, rest on jack stands and then inspect both half shafts to see if one may be slightly out. I can't quite recall but I thought our half shafts are located in place with a tension pin of some sort? Guess I'll find out when I replace one of them this spring.
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 01-19-2013, 10:45 PM
Well I finally got under the car and went over everything. Guess what? I had pulled the drivers side drive shaft out of the diff housing about .5 inches. I wiggled it back in and it fixed it. I am a little embarrassed that I didn't check this when I was finishing up the first time. Thanks for the suggestions guys.
alia176, They are pinned into the shaft of the differential, however that shaft has a little play. Thanks for the info.
On a side note I replaced my end links and the car is as quite as when it was new. If you are having strange sounds coming from your front end it is well worth the $50 investment. (from Ebay not Subaru)
Dust
Old 01-19-2013, 11:25 PM
The output shafts are held in the differential with a circlip.
Old 02-24-2013, 07:02 AM
Amarsir Amarsir is offline
What an interesting thread.
I just had my struts replaced two weeks ago at a local Meinike (and I generally like this place). After getting the car back I heard a clicking noise matching the speed that would come and go at lower speeds. Figuring something was loose or bent I took it back to the shop and they told me intermediate bushing on the drive shaft is too worn, it's giving too much play, and I should go to a driveshaft expert (which they admit they are not).
Then I find this thread, which is oddly relevant. So I'm wondering what the odds are that the shaft is just out of place? Naturally, I'm willing to believe that any original part on this '96 is fair game for replacement, but especially since the expert they recommended is a few towns over I'd rather not go to that trouble if it's something that can be nudged back in place.
Old 02-24-2013, 07:30 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Oh nice, you're near me. What brand struts did they use? Do you hear it constantly or only when you're driving up near a wall when the sound is reflecting back at you?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 02-25-2013, 06:29 AM
I believe they were Subaru struts, I got them myself from here:
http://svx-motorsport-accessories.st...et/farest.html
I wouldn't say the sound is reflected, only that it seems more likely at lower speeds like when braking. At worst it's loud enough to be worrisome, but that seems short and infrequent.
