Old 12-13-2012, 05:40 PM
Re: Not again! Tick tick tick
Originally Posted by dannmarr View Post
I am so ******! The trans shop called. They have my trans out and would like to see me tomorrow. They claim my car has a 1998 subaru forester trans and diff. They also said the trans and the diff is full of metal, the diff is cracked and the trans has no dowel pins! The flex plate is also cracked again!What else can go wrong! I am so
An 4EAT has seporate resrevours for the differential and transmission, and two different types of fluids.
IMHO if the front differential was (actually)cracked, that would be enough to warrent replacing the transmission.
Metal in the transmission would have nothing to do with metal in the differential, usually.
Old 12-13-2012, 06:20 PM
michael's Avatar
michael michael is offline
What Potholes ???
[QUOTE=svxfiles;717293]
An 4EAT Normally has seporate resrevours for the differential and transmission, and two different types of fluids.
Couldn't fluids mix if a seal was improperly installed?
Wanted: Steering Wheel
Old 12-13-2012, 06:21 PM
What's your point? You do have a 4.44 swap, do you not?
Old 12-13-2012, 06:22 PM
No seals would have been touched typically when doing a swap. The only possible seal that could fail causing issue would allow trans fluid into the front differential, but not the other way. It would fill up the diff case with trans fluid and could cause a failure eventually if not caught in time.
Old 12-13-2012, 08:09 PM
[QUOTE=michael;717295]
Yes, IF the transmission fragged and under pressure pushed some contamanated fluit into the 0 pressure gearbox...
Old 12-13-2012, 08:12 PM
I completely agree with this statement!
And other than the NRA I do not agree with anyone!
Old 12-13-2012, 08:36 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
I always believed it was a 1998 legacy trans that I had. Am I wrong? Why did I think that? I'm pissed because I had the original trans rebuilt, then I had the trans swaped, then I had the flexplate replaced and now the trans is shot? I hardly drive it, the swap was done in 2010.
So, should I rebuild the Forester trans or is there another option?
The trans shop dosen't understand why we swap out our transmissions for a smaller 4 cylinder trans?
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 12-13-2012, 11:47 PM
We swap them for the mechanical advantage of a more correctly geared, otherwise identical 4EAT!
IF Subaru had installed the 4.44 in the first place transmissions would not be our biggest concern!
Old 12-14-2012, 08:58 AM
+1
They've been proven to outlast stock geared transmissions even after coming out of donor cars with over 100k miles.
Old 12-14-2012, 11:03 AM
dannmarr's Avatar
I work for my SVX
Subaru SVX for fun
Old 12-14-2012, 11:57 AM
If the case is cracked, and the oils are contaminated with metal shavings, throw that one away and buy another transmission!
Old 12-14-2012, 12:52 PM
+1
Getting another used transmission is going to be a much better option than even a transmission shop trying to rebuild a Subaru trans. That never seems to go too well.
Old 12-14-2012, 02:41 PM
dannmarr's Avatar
I work for my SVX
Thanks guys. The trans shop has someone who might be able to help. If a used trans can be located, they said I can have it for free. I would just pay for labor. My original mechanic also said he can help with a used trans for his cost, $400. (My mechanics worker actually did the swap 2 years ago, he has been long fired for using drugs) That explains alot.
Subaru SVX for fun
Old 01-06-2013, 08:43 AM
dannmarr's Avatar
I work for my SVX
WTF!?? The Trans shop has my car for 7 weeks and they are still not finished. Is this a common thing? They keep giving me excuses about parts that need to be replaced and ordered. Hope this is all worth it.
Subaru SVX for fun
Old 01-06-2013, 08:50 AM
michael's Avatar
What Potholes ???
My God, what a tough time you're having with this! It's a little late but, there is a guy in scranton who has done excellent work for me in the past. The owner's name is Ting and the business name is M&D Auto Sales. I know it's far but he really knows his way around an SVX.
https://www.google.com/url?sa=D&oi=p...3DUS%26hl%3Den
