Old 10-11-2012, 09:52 AM
WYOSVX's Avatar
WYOSVX WYOSVX is offline
Rear Bearings Installed...Question of Quality
I bought NTN rear bearings for my SVX, the passenger side rear was pretty loud.
I cleaned them and re-packed with lithium-based, high temp bearing grease.
Stupid thing: While blowing out one set, I got the race (cage) spinning pretty fast, making a cool whirring sound for about a second, then it exploded. Lucky I didn't lose an eye. My bad. Expensive fun. Ordered a replacement.
Ran out of time, want to drive my car, so took it to my mechanic. I've found him to be highly qualified, over the years; at least for our small town.
He had their assistant do the job. He broke a set during install, something about over-torqueing, wheel not turning, backed off the torque- too late. They had the printout I gave them to tell them about the SVX bearing oddities and I made a point of telling them before without being the know-it-all shade-tree mechanic. Judging by the greasy smudges, they read it. Again, they're good mechanics. I probably would have screwed it up, too, then had to wait till I had more time to fix my screw-up again. They paid for the bearings.
I think AP Warehouse is okay with replacing a broken set, as it was installed by a qualified shop.
Here's the question:
NTN bearings have plastic holders (cage) for the bearings. My mechanic said that, at least with GM, they went with those over metal to make them quiet but they haven't found them to last as long as metal. He likes metal.
I talked to AP Warehouse, they weren't sure which might be metal, but, at least, Timken were plastic. That leaves Beck-Arnley and NSK, that I know of.
Any opinions? Metal vs. plastic?
Any personal experience?
Old 10-11-2012, 10:40 AM
dragoontwo dragoontwo is offline
Re: Rear Bearings Installed...Question of Quality
The holders I believe are called the cage. The races are what the bearing actually rolls on, inner and outer.
'92 SVX LS Pearl White - 6mt
Old 10-13-2012, 08:18 PM
WYOSVX's Avatar
Thanks! Made slight corrections.
Any opinions about bearings?
I bought the NTN because they're made in Japan.
Old 10-13-2012, 09:58 PM
Originally Posted by WYOSVX View Post
Thanks! Made slight corrections.Any opinions about bearings?
I try to use only Subaru bearings, unless the customer objects.
Recently I replaced a rear wheel bearing on a Subaru, (not a SVX) and the bearing was BALL BEARING!!!!!
Not a roller bearing!
The customer could only speculate that a bodyshop "went cheap" on a repair years before.
Not his call, not his choise!
Old 10-14-2012, 08:37 AM
WYOSVX's Avatar
Wow! Someone must have robbed them off a bicycle.
At least mine weren't ball bearings. I'm hoping that, riding in high quality grease, my roller bearings will last pretty well with plastic cage.
Old 10-14-2012, 11:40 AM
Impreza and Forester are built with ball bearing rear wheel bearings ,the replacement is a 90's style Legacy bearing
Old 10-14-2012, 08:42 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Torque and grease is important. My last mechanic replaced the same rear bearing 3 times because it failed. I got tired of this, so the last time I replace it myself. I made sure to repack it and torqued it to specs. I've been driving it for many years now.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 10-14-2012, 09:58 PM
The ball bearing wheel bearing that I replaced was from a 2002 Impreza.
Tonight I replaces ANOTHER 2002 Impreza wheel bearing, and, yes, it was ball bearings, and the replacement, (National) was roller bearing.
Old 10-15-2012, 06:09 PM
never repack a factory bearing ,it voids any warranty ,they come pregrease and run
Old 10-15-2012, 07:13 PM
Trophy my friend, with that kind of advice you will be replacing wheel bearings often in your SVX. It's been proven time and again that the shipping grease on OEM SVX bearings is just that, not lubricating grease.
Old 10-15-2012, 08:36 PM
dannmarr's Avatar
I work for my SVX
My mechanic had that same mentality, that's why my bearings failed three times! He wouldn't listen.
Subaru SVX for fun
