Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Interior Mods
Old 09-29-2012, 05:28 PM
H-top H-top is offline
rear heater bars?
are the rear heater bars on the svx glued onto the glass or cast
inside the glass?
i need to know this for stripping tint from the glass, if it is on it,
i will lose the heater bars.
cheers all
Old 09-29-2012, 05:40 PM
Re: rear heater bars?
They are glued or printed on, not cast inside. Is it not that easy to remove the tint without also removing those?
Old 11-28-2012, 01:41 PM
niko_au niko_au is offline
Yer they are just glued on.
You can remove the tint without the heater/demister bars coming off tho.
Pro tinters use a steam machine to melt the glue and the tint just peels away, you cant just use a razor blade to remove any remaining glue like you to on the side windows. Can buy a heavy duty window cleaner, funily enough called tint glue remover made for cleaning any remaining glue without using a razor blade and leaving the demister strips intact. May be able to use prepsol or metho ect for the same effect.
cheers
Nick
