Old 09-23-2012, 09:19 PM
stiguy's Avatar
stiguy stiguy is offline
Steering rack rebuild kit?
ive been looking for a rebuild kit
found this one.. anyone know if it will work?
https://www.rockauto.com/dbphp/x,car..._Seal_Kit.html
#1 1994 Ls ebony parts car-rip
#2 1994 L laguna blue - sold
#3 1992 Lsi pearl white - sold
#4 1992 Lsi pearl white -Ate two engines - Rip
#5 1994 L Laguna Blue fwd - Now Awd and manual - 03 wrx 5mt - 18's stern warp st4s - totaled hit a tree
#6 1992 Lsi custom orange parts car
#7 1992 Lsi green 4.44 swap. Currently for sale
#8 1992 Lsi custom pearl white. Project car... sold
#9 1992 Teal 4.44 swapped... sold
#10 1995 Laguna Blue. Sti 19 wheels,
#11 1994 Laguna Blue. Came with #10 engine and trans are out but plan to put it back on the road. Willing to sell it at any time! 😂
Old 09-24-2012, 12:14 AM
kwren's Avatar
kwren kwren is offline
Re: Steering rack rebuild kit?
I think there are 2 different types for the SVX but not sure if that makes a difference.
Keith
Old 09-24-2012, 07:30 AM
Keith
The parts of the rack that matter are identical. The speed sensitive just have a solenoid fitted to adjust pressure. This would require one extra o-ring that could probably be matched easy enough should it be missing.
Old 09-24-2012, 07:32 PM
stiguy's Avatar
So that kit will work to ur knowledge?
Old 09-24-2012, 07:38 PM
SVX8588's Avatar
SVX8588 SVX8588 is offline
That's a bit cheaper than the one I bought:
http://www.pskits.com/catalog/rackki...471ac316caf870
I did both the rack and the pump at the same time.
Glen
SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery
2002 F550 74K
SOLD - 2000 F450 215K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 09-24-2012, 07:57 PM
stiguy's Avatar
Did u need special tools to rebuild it?
Old 09-24-2012, 08:06 PM
SVX8588's Avatar
Nope, you just need to be creative with common tools
I honestly can't remember. I brought it to a mechanic friend and he helped me with it. It's nice to have a lift to get the rack out of the vehicle!
and don't forget to tighten ALL the power steering lines before starting the car. (learned that the hard way with over a quart of synthetic ATF on the floor!)
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 09-24-2012, 09:36 PM
Ha, I did the same thing. Forgot one clamp and it just gushed right out.
Old 09-25-2012, 07:26 AM
alia176 alia176 is offline
I've had my rack rebuilt by someone many moons ago but lately I've been noticing some play in the steering wheel. The tie rod ends are new so that's not the culprit and I don't *think* a typical rack & pinion doesn't have means of removing lash from the unit (like a typical steering box).
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 10-06-2012, 09:08 PM
stiguy's Avatar
So got my kit from rock auto. Gonna rebuild it tomorrow I was wondering if anyone has info on how to rebuild it? or a link to the service manual?
Thanks
Old 10-07-2012, 01:01 AM
THE NEW GUY THE NEW GUY is offline
take pics or video and share it with us.
BTW, I added 1/8 of Lucas power steering fluid and I think it increased the system presure because now I' ve smaaall leak on the O-ring of the main pressure in port. Not too bad but I hate when my car drops oil, specially on my drive way!
Old 10-07-2012, 09:12 AM
stiguy's Avatar
Okay I will as it doesn't look like there is a wright up on it
Going to get coffee now then gonna get started
Old 10-09-2012, 05:20 PM
stiguy's Avatar
Fail!!! I got the rock auto kit and followed the Subaru service manual and put all bac together and now it literary sprays fluid out of the boots idk what I did wrong.... Any one rebuild one with secuess?
Old 10-10-2012, 07:32 PM
SVX8588's Avatar
Yes sir. But I had a mechanic helping!
Did you use ALL the seals and o rings in the kit? And did you have everything lubed up good before putting it back together?
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 10-10-2012, 10:11 PM
stiguy's Avatar
um.. no i didn't use all of them... there were a few of the thin blue ones left as i did not see where they went to... also i didn't rebuild the valve assey. and some of the seals were to small for the main rack shaft.. any suggestion?
