Quick questions
A couple of really basic questions:
Is the little pocket / pouch thingy in the left hand side of the boot for spare wheel tools, etc? My spare wheel / tyre is also the original and never been touched - would it be unwise to use this tyre after 20 years? Still looks in perfect condition. How do you open the fuse panel near the driver's kick panel? Seems tight and I don't want to break it. Cheers, Grant |
Re: Quick questions
I think the pocket thingy was for a cd stacker
I believe the fuse panel pulls open The spare wheel will be fine no weight on it and out of the elements
92 pearl SVX about to revive 92 Black 4ws (Jap spec) SVX 93 black SVX 93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear 95 bright red SVX 96 emerald pearl SVX about to revive |
Re: Quick questions
If you look at the fuse panel well enough (most people aren't inclined to get very close to it, being as low and tucked under there as it is), you'll see that there's a little lever you press to unclip it and then it opens easily.
Re: Quick questions
Thanks. The driver's side footwell fuse box comes off by pulling it out from the bottom of the cover.
Does anyone know if you can get clear side indicators (instead of the amber colour)? |
Re: Quick questions
yes the JDM and oz svx's came with clear as standard, my 4 svx's all have clear, the US cars came with amber
Re: Quick questions
ahh you mean the little ones on the side guards, no they are orange but clear ones would be good
Re: Quick questions
Re: Quick questions
They will if the lense is clear and the bulb is orange
Re: Quick questions
Yeh, the ones on the side guards are what I meant. I just had a look on Subaru SVX Images and a lot of the US SVXs don't have any side indicators at all - makes the lines look smoother. Haven't come across any clear lenses though ......
Wouldn't mind swapping the rear middle light panel from a US car either - the two reversing lights look better being closer together than the Oz spec cars (in my opinion only of course). Loving my SVX! |
Re: Quick questions
Just found a pic of what one looks like with a clear lense:
http://www.smcars.net/forums/attachm...993-aset39.jpg And heaps with no side lense (and the nicer rear middle light panel): http://static.cargurus.com/images/si...pic-38633.jpeg |
Re: Quick questions
That's not a clear lens, that's a black-and-white photo.
The US SVXes don't have them. You could get a little marker light from almost any car really and it ought to work, really simple to wire up, you just gotta make a hole for it in the fender. My wife's lancer I noticed the little fender marker is clear and pretty close to the right size, maybe a little on the big side. There are probably generic ones too.
Re: Quick questions
for clear guard blinkers i just used GC8 wrx items and sanded the sides down until lthey were a snug fit. i used the original svx bulb holders in the new housing and fitted orange bulbs. worked a charm.
Re: Quick questions
Great idea - have you got a picture of yours?
Re: Quick questions
Re: Quick questions
