Look for a switch guys
I would LOVE it if somebody had the power mode switch that the japanese SVXi had, but that's not practical. So, does anyone have a shift-lock switch they'd give/sell to me? i'm just gonna put that where the power mode switch would go.
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
Re: Look for a switch guys
I'll check and see next time I'm looking through stuff.
Just looking at the switch gear on mine, with a JDM Power switch, and you should be aware that: the power switch is a locking switch (also lit at night) while the shift lock button is not, and: the lock switch also acts as a mechanical lever to unlock the safety mechanism in the shifter, not as the electrical on/off locking switch that you want. Keep feelers out for the correct switch from JDM market.
Glenn
"The only thing necessary for the triumph of evil is for good men to do nothing" Aaron Burke 1993 25th Anniversary Edition #63 of 301. R.I.P. Rojo 7/24/2008 She saved my life! 1997 Ebony Mica Pearl LSI. BLACKBERRY 1998 5-Spd Legacy GT Wagon in Glacier White: NUBURU 2005 Cadillac STS in Sandstorm Metallic: STORMY Veteran and farthest traveler of 1st SoCal2MuseumsMeet2010. http://www.subaru-svx.net/photos/user.php?RojoRocket |
This is a possibility.
. Back in 2003, Mike Novosel "nubs" did a similar setup, using the shift lock button and a micro-switch, to operate his garage door opener. Should not be that difficult to make it work with a PWR switch. Of course there are other options. This switch operates my secondary alarm indicators and my LED grille light. Easy access with my thumb. Looks factory. .
Personally, I would do the simplest solution, based upon the high-beam switches mounted on the floor of the older '50 and '60 cars.
Whenever you need the PWR mode, just depress it with your left foot to activate, press again to return to normal. An LED indicator could be wired it to light when it's engaged. No holes to drill or modifications. Easy wiring from the TCU. Completely invisible and removable. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 11-19-2011 at 05:09 PM. |
that is EXACTLY what i want. i am going to put a switch somewhere else for the mean time, but that is my goal. not surprised that you found the exact thing i wanted you're pretty much an svx dictionary, john.
The German SVXs have two switches for this purpose. Electrical so almost plug and play.
On for the Manual control and one for the power antenna. In fact, the button of the side of the gear selector lets you choose between ECON (normal) and POWER. Maybe some of our European members can get a part number... . .
Thread Tools | |
Display Modes | Rate This Thread |
