Old 09-04-2011, 06:45 PM
Rod.'s Avatar
Rod. Rod. is offline
I have a donor '92 motor for my '97
I bought a complete '92 car this weekend and towed it home (500 miles) so I can replace the motor in my '97 that has spun crankshaft bearings. These are are my 1st and 2nd SVX's, the '97 was bought in June. I'm hoping that this doesn't become a habit... ;-)
Anyway, is there any advice you can give me to pass on to my mechanic so I'm sure he gets this transplant sorted out OK?
For example, he thinks the different engine monitoring systems in the '92 will be a problem. Earlier advice from here basically said to plug and play. Is it really that simple?
Thanks,
Rod.
'97 Ebony LSi #426, CDM (1 of 51 in '97), 185k km, rebuilt engine & transfer case; 22mm Bontrager RSB; 4300k HID 9006 bulbs SOLD
'92 Ebony LS-L #6851, USDM (sold)
'08 Forester (wife's)
'06 STi (traded for the Forester)
'94 Legacy wagon (sold)
Old 09-04-2011, 07:34 PM
XT6Wagon XT6Wagon is offline
Re: I have a donor '92 motor for my '97
at most you will need to swap intake manifolds and a couple sensors on the block. *IF* you need to. Which is all about getting the electronics your ECU expects, and not mechanical issues.
engine mounts should swap across blocks without issue.
Old 09-04-2011, 09:08 PM
Green1995SVX's Avatar
Some others will chime in with specifics, but I know for sure that the engines themselves are the same. There may be some electronic bits that need to be swapped, but the mechanical stuff is the same.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 09-04-2011, 09:41 PM
Nothing needs to be swapped. The only issue that could ever be run into is a Cali spec car that the ECU looks for the EGR temp sensor, so swapping in a non Cali spec engine will throw a code for that unless the ECU is swapped or the temp sensor is swapped.
Other than that, the added 3rd o2 sensor is part of the body/dash harness.
Old 09-05-2011, 07:08 AM
Rod.'s Avatar
Great! Thanks for the info.
The PO told me that the '92 is a US car, so can I tell from the VIN is it's Cali spec?
JF1CX3532NH106851
Rod.
Old 09-05-2011, 08:25 AM
JF1CX3532NH106851
Just look for the EGR temp sensor located on the very back of the intake manifold on the passenger side. There will be a couple wires and a connector sticking up if it is, and just a plain bolt in there if it's a Federal emission car.
Basically sitting right on top of where the EGR pipe enters the intake manifold.
Hope that helps and good luck with the swap.
Old 09-05-2011, 11:49 AM
It looks like it started its life in Texas, so I doubt it's a California emissions car.
File Type: pdf CARFAX Vehicle History Report on JF1CX3532NH106851.pdf (219.2 KB, 163 views)
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 09-05-2011, 01:04 PM
Rod.'s Avatar
Thumbs up Re: I have a donor '92 motor for my '97
Hey, thanks very much guys for the tips and especially for the Carfax!
Now all I need is time, patience, and dollars...
Rod.
