Old 08-10-2011, 05:58 PM
Silverstreak Silverstreak is offline
Ac problems
First off hello everyone I'm new here
I have ac Problems the ac won't turn on I have changed the fuse relay and now the compressor but nothing if I put the controls on auto nothing happens the compressor won't switch on
Is there a ac switch on these cars sorry I have a 92 lsl
Any advice would be great thanks aaron
Old 08-11-2011, 04:57 AM
Re: Ac problems
Have you charged the system?
Old 08-11-2011, 05:28 AM
Re: Ac problems
If the freon has leaked out to cause it to become low, the compressor will not engage as a safety measure, Could be something as simple as deteriorated o-rings and a simple recharge.
When was the last time it was charged and/or operated normally?
You checked the 10A fuse under the hood? Do the lights on the climate control panel work and do you have the fan speeds?
Old 08-11-2011, 06:50 AM
Re: Ac problems
The freon might be low yes I have checked the 10amp fuse it's good the control Panel works fine and I have all three fan speeds
I can turn the temp down to 65 and it won't engage the comPressor
I will have the system charged and see what happens thank you
Old 08-11-2011, 05:33 PM
Re: Ac problems
I tried to charge the system today
It has already been converted to r-134a I got some freon autozone and it would only take about a quarter of a can because compressor wouldn't turn on to allow it to circulate any suggestions would be great thanks again for the help Aaron
Old 08-11-2011, 06:01 PM
Re: Ac problems
http://www.subaru-svx.net/forum/showthread.php?t=58003
Also post #2 here: http://www.subaru-svx.net/forum/showthread.php?t=57173
Try pulling codes from the climate control unit and see what comes up.
Did you fill it from the "high" side or the "low" side? Some useful info here: http://www.subaru-svx.net/forum/showthread.php?t=57769
Old 08-11-2011, 08:02 PM
Re: Ac problems
Thank you I will check the codes tomorrow
I filled the low pressure side
Old 08-12-2011, 10:54 AM
Re: Ac problems
I checked the codes and 14 is the magic #
evaporator sensor open
Where could I find this sensor and does it need replaced?
Thanks again for all the help
Aaron
Old 08-12-2011, 12:35 PM
Re: Ac problems
That's the sensor inside the white plastic box under the dash on the passenger side of the car. You would need to let the freon out again to remove the box. The sensor is either defective or not plugged in. When I got that error the sensor had a poor connection.
Old 08-12-2011, 04:05 PM
Re: Ac problems
Thank you I will tackle that this weekend
I really appreciate all the help I've recieved from everybody
