Old 08-08-2011, 07:20 PM
The Molinator
Propeller Shaft U-joints
I had trouble putting in the Euro-Drive C-clip replacement ujoint I got from Canada .. suggested here. One shaft (axis) worked fine.. one was too tight, bcuz caps had to b pushed too far in (together) to get C-clips in!
New driveshaft OEM online includes center bearing.. so $488! So far, I can't get them to leave the bearing ($170) out.. even tho I just bot and installed one.. Hmmm?
Know any other source for OEM propeller shaft w/o center bearing.. ? How about a Chinese version of new.. like svxfiles axles.. ?
Thanks..
Jim
Old 08-08-2011, 08:33 PM
Re: Propeller Shaft U-joints
New axle from China, $70.00 with lifetime guarentee.
New axle from Japan, $229.54 through www.subaruparts.com.
Hey, they came down.
No luck on driveshafts so far as I know.
Old 08-09-2011, 01:58 PM
steamer99's Avatar
steamer99 steamer99 is offline
That is not bad considering I was quoted $1050 for a driveshaft for my 97 outback from the stealership
current stable, subject to change without notice:
1995 Red SVX, 4.44 & Quick Change
2014 Nissan Titan S 4X4
1992 Teal SVX parts car
