Old 07-09-2011, 09:32 PM
Schralper's Avatar
Schralper Schralper is offline
A/C Trinary switch, replacement part?
So for a/c trinary switch replacement, the whole pipe assy is only option?
WFO!
http://www.cardomain.com/id/Schralper
"You all laugh cuz I'm different
I laught cuz you're all the same."
Old 07-09-2011, 10:58 PM
Re: A/C Trinary switch, replacement part?
Yeah unfortunately you have to buy the whole assembly (hi pressure line from condenser to receiver. Appx cost is about 150
Old 07-10-2011, 10:34 AM
Schralper's Avatar
Superduper & leeme guess, the oring on new trinary switch, still has to be changed to green r134 oring.
WFO!
Old 07-10-2011, 11:04 AM
I don't know about that. Don't see why the new o ring can'tj be used.
Old 07-11-2011, 12:13 PM
Please note that Subaru only sells a new trinary switch as a complete unit (high pressure pipe). You mentioned your problem is a leak, not a malfunctioning trinary switch. Perhaps simply installing a new o-ring would solve your issue. If however, your trinary switch is malfunctioning I have a used one (not sure of it's working condition but maybe worth a shot). There may be an aftermarket option too...
