Old 07-06-2011, 02:14 AM
jfornes jfornes is offline
94 Svx L
I just bought a 94 with 128000 miles on it and I have few questions. How many quarts of oil does it take and how many quarts of transmission fluid is needed. I'm thinking of using the amsoil product for both applications and I need to know how much to order. I would also like some input on what rotors and brake pads you guys would recommend.
Thanks,
Jason
Old 07-06-2011, 02:41 AM
Re: 94 Svx L
oil capacity is 6.3 quarts not including filter.
Trans capacity completely empty is something like 11 quarts or so, but you will only be able to put about half that in. To get the most trans fluid out, remove the pan, remove the filter, and let it sit for a couple hours. I've been able to get as much as 7 or 8 quarts out of the transmission by doing it this way. If you just do a drain and fill, only about 4-5 quarts will come out.
Old 07-06-2011, 11:26 AM
Re: 94 Svx L
Thanks Nate. Appreciate the info.
