Old 07-05-2011, 11:55 PM
kwren's Avatar
kwren kwren is offline
code 11... Crank Angle Sensor
What is that all about? first got the 11 code right after my "200,000 mile Burgundy looking SVX" got a engine replacment from Japan and that has been 3 months ago... Happened again yesterday. Engine raced up a couple of times and died as Check engine light came on. I immediately checked for the code and got code 11.
Maybe something wasn't replaced from the old engine that should have been done? I think there are some things that are not compatible... Any ideas, anyone?
Thanks,
Keith
Old 07-06-2011, 02:39 AM
Re: code 11... Crank Angle Sensor
Replace it with a new or known good used one.
That is all
Old 07-08-2011, 04:52 PM
Jake@FAPFab's Avatar
Jake@FAPFab Jake@FAPFab is offline
11.24:1 E85
it is likely the wiring right to the plugs, they are prone to cracking and such
Old 07-14-2011, 10:17 PM
kwren's Avatar
Where might this "Crank Angle Sensor" contraption be found on the car
Thanks,
Keith
Old 07-15-2011, 12:04 AM
Cam Cam is offline
Just below the alternator, mounted directly on the oil pump. It is easy to remove, but you may have to unbolt and lift the alternator out of the way.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 07-15-2011, 11:54 AM
kwren's Avatar
Thank you!
Keith
