Old 06-16-2011, 06:18 PM
Huskymaniac's Avatar
Uses the ignore feature
Is there a problem with this parts diagram?
http://www.subaruparts.com/diag/?mod...ategory=020A-1
I am looking at the clips that hold the coil pack wires. Shouldn't there be two no.1 and two no.2 clips versus 3 of one and 1 of the other?
Tony
Old 06-16-2011, 06:31 PM
XT6Wagon XT6Wagon is offline
Re: Is there a problem with this parts diagram?
your link doesn't work, but I can go check to see what my motors have on them as far as wire holders.
Old 06-16-2011, 06:44 PM
hahah spare motor has 3 3wire spacers, and 1 2 wire spacer. SVX has 3 3wire spacers and 1 two wire spacer.
Stranglely SVX had the 2 wire on the drivers side and the spare motor had it on the passenger side.
who knows which was messed with.
Anyway, if you want you can get this stuff for spark plug wires at autoparts stores, and place like jegs/summit if you don't want the factory stuff.
Old 06-16-2011, 09:48 PM
The left and right side clips are not identical as you would think. The diagram is correct.
When I had my valve covers aluminum ceramic coated, I replaced all of the coil wire clips.
