Old 06-15-2011, 08:33 PM
Change a PVC
How do u change the PVC valve ? Pictures and instructions would be great.
Old 06-15-2011, 09:19 PM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Re: Change a PVC
Look at my thread "alternative option to replace PCV" OR look in the How-To documents under "maintenance" and there is a .pdf file of changing PCV valve.
1995 Subaru Svx L / AWD
Old 06-16-2011, 10:18 AM
msvx95's Avatar
It's just a phase
Re: Change a PVC
But if you REALLY want to change what you asked for in a PVC..go to the plumbing section in your local hardware store
Old 06-17-2011, 05:12 AM
Re: Change a PVC
Here is a picture of it's location....
It just unscrews...but is a Real PITA to get too......
Old 06-17-2011, 05:41 AM
Re: Change a PVC
Yea PCV (been working in Lowe's plumbing dept tooooo long . ) I never removed a throttle body so maybe that would be more of a challenge than I want to attempt. the car is using about 1 qt of oil in 1,000 miles and someone told me it could be the Positive Crankcase Ventilator . What would a dealer charge to do it ? no smoke no smell and the engine does have a very slight valve cover gasket leak . should I even worry about it?
Just thinking ::: Has anyone ever considered relocating this thing. I mean a fitting a piece of hose and you would not have to do this again. Technically the PCV could be put in the glove box <LOL>
Old 06-17-2011, 08:02 AM
Re: Change a PVC
Can be done without removing the throttle body...several of us have made a "Crows foot" wrench to get it out from the top, but even then it is tough getting the hose loose, and back on
Old 06-17-2011, 08:17 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Re: Change a PVC
I was able to pull the hose by reaching under the manifold between the runner and the throttle body on the driver's side. It's tight, but it can be done!
Old 06-17-2011, 08:44 AM
Re: Change a PVC
Like Huck says...making one of these will help:
Old 06-17-2011, 10:15 AM
msvx95's Avatar
It's just a phase
Re: Change a PVC
I struggled with the crow's foot and the other small vaccuum hose that snakes out of the top....barely any room to turn it, but yes it can be done with a crow's foot.
I recommend you work on this just a few hours after the engine is off so the hose and intake is still warm. It's easier to get a warm hose off the valve than it is with a cold stiff hose.
Old 06-17-2011, 11:04 AM
Re: Change a PVC
Here is alternative procedure for changing the PCV
http://www.subaru-svx.net/forum/show...&highlight=pcv
And another tool photo
