Contact cleaner
Is CRC the best? Has anyone ever had O2 sensors give a slow response code due to dirty contacts? I put a new O2 sensor in last fall and it occasionally trips a code for the same slow repsonse error. I bought Bosch sensors so they should be high quality. The fact that it is intermittent says contacts to me.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
Re: Contact cleaner
My 96 has been doing this for a few years now. I've tried bosch and ngk sensors,cleaned all the contacts except at the ecu,cleaned the injectors and nothing has worked.I even cleaned the bungs so I know they make good contact on the cats.It returns every 2 drive cycles. Just like the FSM say's it will. I just clear it when it pops up.next step is exhaust. It runs fine but uses a little more fuel than normal.Btw, the code I get is po145. Good luck and let us know if you figure it out.
Re: Contact cleaner
I replaced bank 1 sensor 1 and it has been fine. I replaced bank 1 sensor 3 and it still gives me this error intermittently. I can't remember which code it is, numerically, but it is the slow repsonse one. That usually means the sensor needs to be replaced but this is a new Bosch. I suppose it could be a faulty sensor but I have also heard it could be bad contacts.
Re: Contact cleaner
Was it with a Bosch Universal or OE style?
*Yea 2000 posts!
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel Last edited by michael; 06-13-2011 at 05:00 AM. |
Re: Contact cleaner
It was the one with the connector on the end, not the bare wires.
Re: Contact cleaner
I had bad luck with the universal type (bare wires). OEM type should have been fine
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
Re: Contact cleaner
What kind of bad luck?
Re: Contact cleaner
Keep in mind mine is a 92. I was getting a CEL after the new one was put in, I forget what code exactly.
Re: Contact cleaner
Did you eventually resolve the issue? If so, how?
Re: Contact cleaner
I returned the sensor for a new one.
Re: Contact cleaner
Re: Contact cleaner
OEM is Bosch.
Re: Contact cleaner
Hang in there, Tony! Keith |
Re: Contact cleaner
Fine people, I will edit my response. But I still ask...can someone finally ban this jerk for good? Trevor was a prince of congeniality and a great addition to the community compared to this miserable excuse for a human being. And to think this guy facies himself a wise old man. What great philosophical teachings have ever said it is wise to instigate and antagonize other people to drag them into your misery so you will have company?!?!?!?!
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 06-25-2011 at 08:35 PM. |
Re: Contact cleaner
That is not consistent with what I have read in other threads and my remaining OEM sensor does not look like the Bosch sensor. I think denyo said in another thread that others have claimed that the ECU seems to only like OEM sensors and that NGK and Bosch have caused him the same issues. The Bosch sensor I used for Bank 1 Sensor 1 seems to be working fine as a replacement. This appears to only be an issue with the extra sensor (sensor 3) that only the OBD2 cars have. If the code returns I will probably swap sensor 2 and sensor 3 to see what happens.
