Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Interior Mods
Old 11-25-2010, 04:34 PM
svx 420's Avatar
svx 420 svx 420 is offline
pistons n cams
im tryin to build up my motor..i was wondering if i would have to take out the whole motor to install my pistons n cams does an1 hava answer 4 me? thx plz help
Old 11-25-2010, 04:46 PM
Re: pistons n cams
Are you seriously asking if you have to pull the motor out of the car to change the pistons in it?
Old 11-25-2010, 04:48 PM
svx 420's Avatar
Re: pistons n cams
yes i am am not a mechanic buddy simple question i need a simple answer ,just wondering how much i need to invest, dnt be mad cause u got 227000 on ur svx no **** rollin restoration
Old 11-25-2010, 04:53 PM
Re: pistons n cams
If you're not a mechanic you won't be changing out pistons yourself, so why ask in the first place?
Short version? Several thousand. Figure ~$3000 for pistons and cams, probably another $2500-4000 for machine work, reseal kit, new crank/rod bearings... You also need some sort of engine management since the stock MAF runs out at ~250HP. I doubt you'll get it done for less than $7000. Probably closer to 10K to do everything properly.
Old 11-25-2010, 05:05 PM
svx 420's Avatar
Re: pistons n cams
thx man good to knw i didnt knw id have to get machine work done as well
Old 11-25-2010, 10:32 PM
Banned
Re: pistons n cams
lol I can see much fail in this job... lol this isn't a honda... the EG33 will take a lot more work to build than I think you'll be willing to put in. If you are serious about this however hit me up and I can get you all the parts you need to build the engine for a good price.
Old 11-26-2010, 12:12 AM
Cam Cam is offline
Re: pistons n cams
If you look in my profile under threads I have started then you will see some of the work that it takes to build the engine. Should give you a rough idea. I am 7500 dollars into my build. Not done quite yet. My thread is called 11:1 engine build.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 11-26-2010, 06:52 AM
sicksubie's Avatar
Re: pistons n cams
That is 222,700 kilometers on the car not 222,700 dollars invested
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 11-26-2010, 10:12 AM
Re: pistons n cams
This is of course all assuming that he wants to get it done properly. You could save a huge amount of money from that if you pulled the motor, popped the heads, swapped pistons right there, dropped the heads back on with new HG's, drop the cams in, put it back in the car and start it up. Of course this wouldn't allow him to re-hone the cylinders... Or check the bearings... So the car might produce 300 HP for a few minutes.
Old 11-26-2010, 12:38 PM
Huskymaniac's Avatar
Uses the ignore feature
Re: pistons n cams
What if he just replaced the cams, MAF and injectors with higher flow versions and an upgraded ECU from Mike? The engine would be interference but a new belt should give some piece of mind there. How much would that cost and could a DIYer do it? How about if you skipped the new CAMs? What is the HP improvement with simple mods like this?
Tony
Old 11-26-2010, 12:52 PM
sicksubie's Avatar
Re: pistons n cams
Someone correct me if I am wrong but I dont think there is any cam profile you can put on the stock valvetrain that would turn it into an interference motor...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 11-26-2010, 01:13 PM
Cam Cam is offline
Re: pistons n cams
Not that Mike sells anyways, but I am not sure what the valve trains max length of travel is. That would be a good way to get a little more power out of the engine for not too much cash, though. Still gonna cost you 2 grand or so.
Cam
'92 Ls-L Dark Teal
Old 11-26-2010, 02:57 PM
Re: pistons n cams
Perhaps I was under the wrong impression. I thought his NA cams would result in interference unless you also used his pistons.
So if you just popped those cams in, upgraded the MAF and fuel injectors and installed a Stage 2 (is that correct?) ECU, how much HP would that result in?
And what if you skipped the cams and just did the other three items? I keep seeing commercials for friggin Kias that have 300 HP and I can't help but think that this engine should be able to hit that easily too. Of course, one should probably put in better head gaskets at the same time and make sure all tranny mods (TCU upgrade, valve body upgrade and lower flow resistance tranny cooler) are also installed.
Tony
Old 11-26-2010, 07:11 PM
Re: pistons n cams
How about on a really well taken care of engine with only 70k miles? I was wondering how well it would work to just swap the pistons without any machine work. That plus cams, MAF, stage 2 ecu and injectors would make for a reasonably powerful, relatively inexpensive build.
Old 11-26-2010, 07:56 PM
Re: pistons n cams
The problem is I'm fairly sure the ECUTune pistons call for a slight boring out of the cylinders. Fairly minimal, but not something you'd be able to do with the block intact.
I've got a set of Mike's cams waiting for me at home. I was hoping to have them in this summer but there was a back-log at the manufacturer and I had to put my engine back together before Mike could get them to me. My plan is to just drop those in and see what happens. It's very likely that between the cams, my exhaust (a bit more free flowing than stock) and hopefully my new intake I'll be able to max out the stock MAF. Should be fun...
