Old 08-03-2010, 08:31 PM
Gamesy's Avatar
Gamesy Gamesy is offline
rear diff flange removal
i'm trying to remove the nut to take off the flange to swap it with the new one.
i tried using an impact gun and a breaker bar and it wont budge, need advice on how to take it off.
Old 08-03-2010, 09:01 PM
Re: rear diff flange removal
Are you saying that the nut will not come off?
Old 08-03-2010, 10:19 PM
Gamesy's Avatar
yepp it just wont budge
Old 08-03-2010, 10:21 PM
Cam Cam is offline
I have heard of people grenading the rear diff, but i think this is not what they were referring to
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 08-03-2010, 11:04 PM
Gamesy's Avatar
lol nope the pumpkin hasnt exploded, the flange i'm putting on is the drilled one to support the new driveshaft
Old 08-04-2010, 03:33 AM
I made a tool out of a flat piece of steel to hold the rear diff flange.
It is about 1/4" thick, and 1, 1/2" wide, and about 4' long.
It has one 1/4" hole drilled into it , offset, and a slight curved ground out area so that it clears a socket on the end of the pinion shaft.
With the tool bolted onto the flange, I can use a breaker bar and socket to loosen the flange bolt.
Leverage is your friend.
Old 08-04-2010, 10:21 AM
Gamesy's Avatar
trust me i know. i tried using a cheater pipe on the breaker bar.
Old 08-04-2010, 01:08 PM
StatGSR StatGSR is offline
Send a message via AIM to StatGSR
like svxfiles said, you probably need to attach something to the snout flange to prevent it from spinning while you use a breaker bar or impact to remove the nut.
94 Acura Integra GSR
97 Legacy Brighton - EG33 Swap still in progress
03 Silverado 2500 - Duramax
Old 08-04-2010, 01:45 PM
Gamesy's Avatar
thats the thing its not spinning its stationary and it still wont come off
Old 08-04-2010, 05:28 PM
You might want to borrow a 600ft/lb impact wrench.
For anything that my 250ft/lb guns won't break loose, I have to bust them loose by hand.
Old 08-04-2010, 11:29 PM
Gamesy's Avatar
no go i'm gonna have to swap the diffs....
whats the easiest way to swap the diffs?
Old 08-04-2010, 11:36 PM
What diff do you need?
As far as swapping them it's like ten bolts, and two nuts.
Old 08-05-2010, 05:00 AM
Stick a heavy screwdriver through the flange hole and lock it against the diff body?
Old 08-05-2010, 08:18 AM
Gamesy's Avatar
i have the stock svx diff from the parts car, it was that flange i had redrilled for the new driveshaft, my plan was to just swap the flanges but since it seems like its been welded on i'll just have to take off the rear diff.
do i need to undo the camber bolts for the rear wheels to have enough space to pop out the axels from the diff?
Old 08-05-2010, 03:21 PM
"Pop" the axles before undoing all the bolts. As you lower the diff you can pull the axles out. It is easier without the exhaust pipe in the way.
