Old 07-20-2010, 10:29 AM
macadamianut macadamianut is offline
Window stuck up
Hi all,
Yet another annoying issue to deal with. I rolled up the driver glass the other day and when it reached the top I heard a crazy snapping sound in the door.
Opened it up and found a plastic clip that rides the cable up and down with the ends snapped off. I believe it is this part# 62101PA081 (subaruparts.com)
It attaches to a metal ferrule on the cable and slip-locks into the metal hole fixed to base of glass.
I'm hoping that replacing does the trick and that there isn't something else wrong that caused it to break the first time.
Does anyone know if this is the right part# ???
Thanks,
Mac
Mac
__________________________________
1995 SVX-L AWD, green, 98,xxx miles, ECUtune 1.5, mazda RX-8 wheels with subie center caps, stebro muffler, resonator delete, koni inserts, perrin crank pulley, hella 500 off-road lights, power-slot rotors and .....
1993 968 Coupe 6-speed, 80,xxx miles black, H&R springs
Old 07-20-2010, 10:56 AM
Re: Window stuck up
That IS the correct part.
Replacement instructions with photos can be found by clicking HERE
Also in the How-To documents HERE
Old 07-20-2010, 12:46 PM
Re: Window stuck up
Great,
Will order up today. Now on to replacing the master window switch, hoping someone here has one for sale.
Thanks,
Mac
Old 07-20-2010, 12:58 PM
NeedForSpeed NeedForSpeed is offline
Re: Window stuck up
Yep, that's the PN alright, I've replace about 4 of 'em, all driver window where most of the use is
I'm guessing that the passenger clips will soon fail on me next
The new piece is redesigned, bigger shoulders, not likely to fail. If the car is a keeper, maybe consider doing both sides. You may need to look at the passenger side for reference anyway.
Good luck
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 07-24-2010, 05:13 PM
Re: Window stuck up
Part installed, window fixed. I ordered two in case it happens again. Nice easy fix for once.
Thanks for the help.
Mac
