Old 06-16-2010, 09:24 PM
alex_nz's Avatar
alex_nz alex_nz is offline
Vibration Issues
Hi everybody
I currently running a 1995 JDM and am having trouble trying to resolve a vibration issue.
It occurs only on over run, it is smooth through exceleration with no issues, alternativly I can slightly depress the brake pedal there will be a slight thud (which gets stronger as the car gets warmer) and the vibration dissappears.
the vibration seems to get worse as the car gets hotter, but is apprent from start.
and It seems be more forcefull at lower speed but with a lower frequency, so something I thought must be gear box/drivetrain.
however I have had the gearbox inspected and was told that it is very good condition, and it must be related to the drivetrain or brakes.
I took it to my subaru mechanic who replaced the diff bushes, which didnt resolve it, and he told me it had to be a gearbox issue. as he couldnt find anything wrong with drive train etc.
It feels to be located more towards the rear of the car and the thud slightly foward of that.
any help would be appreciated
Cheers Alex
Old 06-17-2010, 01:46 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Cool Re: Vibration Issues
Hi Alex - mine is the car next to yours in your picture - remember.
I got the following from TurnInConcepts in USA
Since here in NZ the local agent wants NZ$180.00 just for KDT903 rear Diff mounting bushings I went the whole hog & got the guys in USA to add them to the yellow C12 set from Poland
KDT903 whiteline rear diff bushing (US$35.00) - that is where you are getting your noise from - the write-up on how to use it is at
http://svxworldforums.com/
you leave the old rubbers in place & fit the new ones inside the old.
Maybe some one from here can show Alex the actual link
cheers
Steve (1 OF 1)
Old 06-17-2010, 01:50 PM
SURTEESS's Avatar
Alex,
here is the actual link -
http://svxworldforums.com/view_topic...=rear+bushings
Old 06-19-2010, 06:15 AM
BRADY's Avatar
BRADY BRADY is offline
SVX Addict
Send a message via MSN to BRADY Send a message via Skype™ to BRADY
SURTEESS!!!
I have this same "clunk" in the rear end that happens at low speeds.
Is this definitely the problem, the rear diff bushings? It sounds like the correct diagnosis.
I only ask for clarification as Alex mentioned he had replaced the diff bushings and has not updated this thread!
Cheers,
Mike
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com
Old 06-22-2010, 05:10 PM
SURTEESS's Avatar
I have done the link - ABOVE and it fixed the issue that I had.
Old 06-25-2010, 05:55 PM
alex_nz's Avatar
yer sorry laptop is busted, using the old mans on my days off .
the dif bushes were replaced by subtech.
I assumed they would know how to do it, I cant do any work at my apartment, the building managers wouldnt want any oil on their precious concrete.
