Old 07-31-2009, 09:19 AM
MadMaxSvx's Avatar
MadMaxSvx MadMaxSvx is offline
Re: Cranks -- No fuel, no spark?
Sounds stupid but, did you checked the fuses? There is a ignition fuse somewhere..
Old 07-31-2009, 09:21 AM
MadMaxSvx's Avatar
Originally Posted by Jonnycash View Post
I will do that, but I checked the fuses with a test light... not visually.
I have a mechanic freind of mine stopping by tonight to go over this car with me. He has about 25 years experience, so hopefully he will be able to figure something out. I appreciate all the time you guys have devoted to helping me, and I will keep you posted on it.
Ops, you did it already..
Old 07-31-2009, 01:42 PM
NiftySVX NiftySVX is offline
Check to see if the MIL (check engine) light comes on during bulb check. If it does not, the ECU is not receiving power. That's where I would start.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 07-31-2009, 04:57 PM
Jonnycash's Avatar
Jonnycash Jonnycash is offline
Bingo!
We have isolated the problem to the ECU not getting power.
Thanks nifty, the check engine light did not come on.
Now to figure out where it is losing power.
I have been looking over the wiring diagrams, and cannot find a specific wire that feeds power to it.
I would like to run a jumper to that wire and see if that changes things.
Atleaste that way I will be 100% sure of the problem, and I could go from there.
Also,thanks to evryone for the help! This is a great forum.
Everyone here understands that the time spent on these cars is well worth it. This by far my favorite car out of the 25 or so I have had over the years. I'm tired of non-svxers telling me "cut our loses and get another car". They just don't understand
Old 07-31-2009, 05:57 PM
Jonnycash's Avatar
Put power to the red wire heading into the ecu... Fuel pump kicked on... cranked it over, got spark. Now to figure out where the power loss exists
Old 07-31-2009, 06:32 PM
alia176 alia176 is offline
Nice job dude! Considering that you live in CT, could there be corrosion on either the POS or NEG wires? I assume that all grounds have been cleaned?
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 07-31-2009, 06:38 PM
#21 --- Horrible as it may seem, you must suspect the ECU,
Old 07-31-2009, 07:02 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Originally Posted by SoCal LS-L View Post
Can you think of what would kill both spark and fuel delivery? My first guess is power supply, maybe to the ECU, where else should he check?
Did you end up pulling and replacing the #16 fuse??
Old 07-31-2009, 08:38 PM
Good one.
A worthy query, as this fuse also protects the fuse pump relay circuit.
Swapping with a good fuse would settle the issue.
Old 08-01-2009, 04:18 PM
Jonnycash's Avatar
I cannot seemto find a wiring diagram that shows the ecu wires
I am trying to find which wire is supposed to be supplying it with power.
If I can figure out which one it is, I may be able to follow it back and see where the root of the problem is. I powered it up by one of the red wires, and it started, but 2 things I don't know:
-If thats the power wire for the ecu?
-If the ECU iseven supposed to have a full 12v to it?
I think if I find the right diagram, I may be able to see if it goes to a relay, resistor, etc...
I feel alot better now that I have gotten to this point. Thanks again guys
Old 08-01-2009, 04:36 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
You DID download the service manual correct? The ECU wiring is illustrated in the .pdf "wiring diagrams", and its a couple pages in....
You never said if you inspected or replaced the #16 fuse.......
Old 08-01-2009, 04:46 PM
Jonnycash's Avatar
I did inspect and change fuse #16. That was not it.
I have ben looking through those diagrams... Is it MPFI control unit?
Thats the only one I see, but I didn't think that was the ecu.
Old 08-01-2009, 06:23 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Its one and the same, and its also the unlabled one thats represented on the left that has the many teminals... im not sure if thats a typo or what, but its the ECU.
Old 08-01-2009, 06:28 PM
Jonnycash's Avatar
Ok thanks.
Old 08-01-2009, 07:49 PM
Jonnycash's Avatar
Well,t's back up and running
Thanks very much for all the help, hopefully I will be able to help one of you out one day.
Heres what I have determined...
I located the ecu power supply pins.
Checked them... no power.
Scraped a little insulation off of 1 of them, put power to it with a lead wire with a 10 amp inline fuse. Relay clicked, fuse popped immediately.
Cut the wire completely, replaced fuse... still running as we speak, also took it around the block.
I am lead to beleive, one of the power wires on the ecu has grounded out somewhere.
I will never find that needle in this haystack, so I now have a new power wire with a 15 amp inline fuse.
