Old 07-27-2009, 06:30 PM
Unhappy Damn it, what did I do?
Was under the dashboard tonight changing the stock TCU with the ECUTune TCU. Got it changed out and bolted back in place, but now after reconnecting the battery the car won't start.
It will turn but not turn over and I hear a click from under the hood and also a clicking from under the dashboard even when the key isn't turning.
There are a lot of wires in that area and not much room I hope I didn't mess something up. HELP!!!
Old 07-27-2009, 06:35 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: Damn it, what did I do?
Did you check the battery terminals to see if the are free from crud? Also I would double check any plug you see under there again just to be safe. You might have unpluged the ecu by accident.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 07-27-2009, 06:37 PM
Wikedjuggalo's Avatar
Rebuilding
Are you sure you plugged everything in right on the ECU? if you missed a plug your car wont start.
Old 07-27-2009, 07:27 PM
The terminals are clean and everything seems to be plugged in tight. The headlights light come on and the engine turns. When it turns, it dims the lights.
It's too dark and rainy to do more tonight, but tomorrow I will take out the ECU and the TCU. I need to check that the stage 1 chip is in the ECU tight.
I have spares of both of those computers so I guess I can try replacing those. Sure hope I didn't break something.
Old 07-27-2009, 08:13 PM
the_paynter the_paynter is offline
battery is dead
in all seriousness.. try jumping it. I've had weirder things happen?
1992 SVX: JDM STI short geared 6-speed swap, COBB short shifter, slotted cross drilled rotors, Smallcar Clear headlight lenses, 1997 Grill.
1992 RHD WRX: EJ20G, 16G, Cusco Coilovers, Wilwood 4pot/2pot brakes, Defi Genome 60mm gauges, Exotic speed downpipe, 3.5" A'PEXi spec GT catback
Old 07-27-2009, 09:10 PM
Manarius's Avatar
Manarius Manarius is offline
Yup. I'd try jumping it as well. May also want to give the starter motor a good tap to see if it's the starter (although unlikely).
-Jason
-Obi Wan Kenobi
Old 07-27-2009, 09:27 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
No he said it cranks ok but just doesnt turn over. In this situation, I would definitely go back over what I did before it stopped running, maybe a wire was pulled a little out of the ecu or tcu harness.
Old 07-27-2009, 09:28 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I would try turning the ignition about 10-15 times to make sure its not a voltage drop that keeps your starter from engaging.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 07-27-2009, 10:54 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Again.......
Old 07-28-2009, 04:18 AM
I'll get back into tonight, I am thinking maybe the stage 1 chip came loose disabling the ecu. At least that is the 1st thing I am going to check.
Old 07-28-2009, 04:28 AM
Manarius's Avatar
I've had cars crank okay and still not start because their battery was dead.
-Jason
-Obi Wan Kenobi
Old 07-28-2009, 04:45 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Ive heard of this, but in my experience the car will run the EFI a while after being too weak to even crank the engine.
I hereby bet the amount of $65,000,000,000,000 that his problem does not turn out to be the battery, who wants in??
Old 07-28-2009, 04:49 AM
You are lacking good ground to the ECM. Gotta find out where you may have messed with one. The ECM gnd is on the rear pass side of the intake manifold. Is the Check engine light coming on when you turn the key to ON without trying to start it? I would also check to be sure all the connectors on both the TCU and ECM are fully pushed in.
Old 07-28-2009, 12:13 PM
kwren's Avatar
kwren kwren is offline
How on earth can a car crank if the battery is actually dead??
Keith
Old 07-28-2009, 12:19 PM
BoxerFanatic's Avatar
Well, more aptly "nearly dead"
If it cranks too slow, or can't properly charge the coils, or the electrical demand starves the fuel pump which lowers fuel line pressure... the car won't start on a battery that is too low.
"He is only mostly dead. Mostly dead is *slightly* alive."
Have fun storming the castle!
"What you plan, and what actually happens ain't exactly ever been similar..."
1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it.
2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan.
1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun.
