Old 07-22-2009, 12:35 AM
Gamesy's Avatar
Gamesy Gamesy is offline
ok wtf is this cable
when you pull the little garbage/ashtray out from under the stereo housing there's a big black cable that runs there, is that the cable for allowing the ignition to release the key when the shifter is in park? and anyone else have that area get pretty warm?
Old 07-22-2009, 03:13 AM
BRADY's Avatar
BRADY BRADY is offline
SVX Addict
Send a message via MSN to BRADY Send a message via Skype™ to BRADY
Re: ok wtf is this cable
OK. Good Question. I don't know WTF the cable is (your guess is a very logical one) but I do know that that area around the ashtray and stereo emits A LOT of HEAT. All the time. If I put coins in the ashtray, drive for 30 mins, then retrieve them, the coins are HOT!!
This can't be good for the Stereo system.....
Is this heat from the transmission?
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com
Old 07-22-2009, 03:42 AM
Yes guys, it is from the transmission.
There already is a heat shield on the bottom of the car, above the transmission, to reflect heat away. The main problem is the transmission is very near the car floor, and heat leaks into the cabin due to radiation from the transmission.
You could try putting a more effective insulated shield on there, that would be a help. I have also thought it would be very useful to duct some outside cold air to this area, which would blow hot air out from between the transmission and the chassis. I never got around to doing anything about it though.
Old 07-22-2009, 08:28 AM
BRADY's Avatar
SVX Addict
Smile Re: ok wtf is this cable
Cheers Joe! Thanks for the info. As heat is ALWAYS the enemy, I intend to take your advice on the heat shield and cool air ventilation - that is genius.
Old 07-22-2009, 08:58 AM
BoxerFanatic's Avatar
Remind me, if I ever tear-down and restore my current SVX, or another one...
More radiant heat-reflective material on the transmission tunnel.
Maybe some of that mylar lined bubble-wrap insulation that they are marketing for houses and stuff, with the air chambers between two layers of reflective mylar, as a radiant reflector and air-space insulation.
"What you plan, and what actually happens ain't exactly ever been similar..."
1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it.
2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan.
1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun.
Old 07-22-2009, 09:42 AM
Ok, lets brainstorm the overhauling procedure of our SVX and make a list of things to look for/replace/fix when doing the process. Let's start that list and make it a sticky (if possible):
1- Heat shield/cooling the gearbox area.
2- ?
Old 07-22-2009, 09:45 AM
That might make a good stand-alone FAQ-style thread.
But I am a newb owner... so mostly I'll be interested to see what the people who know have to say.
Old 07-22-2009, 10:32 AM
the_paynter the_paynter is offline
Even the 6speed gets VERY hot there. my rubber shield that is suppose to go around the shifter to block some of the heat has a tear in it so it gets EVEN hotter in my car. Not only that but my AC doesnt work (for some ungodly reason) and its been like 30 degrees C here with humity for the past 3 days. This wouldnt be soooo bad if there was more window that rolled down in the SVX haha.
1992 SVX: JDM STI short geared 6-speed swap, COBB short shifter, slotted cross drilled rotors, Smallcar Clear headlight lenses, 1997 Grill.
1992 RHD WRX: EJ20G, 16G, Cusco Coilovers, Wilwood 4pot/2pot brakes, Defi Genome 60mm gauges, Exotic speed downpipe, 3.5" A'PEXi spec GT catback
Old 07-22-2009, 11:35 AM
I was checking the tire pressure the other day, and I noticed the shadows on the ground, of the rippling heat waves just pouring out from under the front of the car. The engine wasn't even that hot. I had just driven a couple of blocks to the gas station. The fenders and hood were nearly too hot to touch. Ambient Temps were in the low 70s.
Seems like this car really could use some heat-extraction, and a bit more airflow management under the hood.
The transmission tunnel is probably one of the few places for underhood heated air to leave the engine bay, as well as the gearbox generating heat itself.
Old 07-22-2009, 01:38 PM
NiftySVX NiftySVX is offline
There are no transmission cables inside the car, in fact, there is only one and it is for the shifter and is outside in the tunnel. You are probably seeing one of the antenna wires.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 07-22-2009, 01:40 PM
That is done electronically, there is no cable involved, btw.
Old 07-22-2009, 02:32 PM
took the words out of my mouth
Old 07-22-2009, 02:57 PM
dcarrb dcarrb is offline
I'm curious about this excessive heating of the console/tunnel, because I've never noticed it in either of my cars. Have the affective cars had some shielding or insulation removed or lost?
dcb
Old 07-22-2009, 04:36 PM
Gamesy's Avatar
thats it, the new bumper i'm making is gonna have an air dam channel piping to cool the tranny.
The thoughts of using mini rads came to mind but hooking a pump and such is too much of a hassle,
simple tubing and free flowing air cooling :P
as for the heat ripples coming from the car ya i can see em when looking through my side mirrors, downside to closed deck engine block and the 1" insulation under the hood i guess
Old 07-22-2009, 04:38 PM
Gamesy's Avatar
and as for the key getting stuck, good to know its electronic but has anyone else had that issue, mine just started up yesterday and its a pain in the ass to get it out. any advice would be appreciated
