Old 07-28-2009, 12:15 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Charging system failure, stranded.
Originally Posted by Mephis View Post
I actually tried wacking the alternator a few times with a hammer and it didn't do anything.
I'm not really clear on how hard to hit it, but I'm sure I hit it plenty hard.
*Disclaimer* My prior advice was preceded with "IF the alternator is shot"
Do you have a multimeter? If so, you can directly measure the voltage coming from the alternator post, and compare it to the voltage at the positive battery post. If theres a big drop, then you have a wiring problem. However more often than not, the alternator needs replacement.
I wouldnt worry about the waterpump..... and you couldnt find it from above because its behind the timing cover..... but its easily visible from below on the driver side (2 small hoses and the lower radiator hose connect to it).
Old 07-28-2009, 12:32 PM
Mephis Mephis is offline
Taking the alternator to a shop to have it tested, I'll update when I'm back.
Old 07-28-2009, 01:30 PM
Alternator is completely dead.
Ordered one, hopefully that'll finally have this goose chase over.
