Tranny is out!
So my tranny went out... something broke while i was on the highway and i lost the high gear as the engine was reving at 5k at 80mph... . Thank goodness that i made it back home, but once i got back, car started grinding in the lowr gears.... and i left it parked. Next time i started the car... rev. is gone and makes a funny noise when i put it in rev. So, the tranny is gone! So sad. But anyway, what subie trannys are available... did some research and it seems 4.44 ratio tranny and diff would help and would be the best bet for an auto tranny replacement? Any other ideas? Anyone know roughly the prices for the tranny and diffs and how much labour is in a shop? Im a noob.. so school me if need to. Just don't be too harsh. Thanks
Re: Tranny is out!
Feel free to call. 301-707-2837 Your best bet is to get a remam from LAN for $1000.00 plus shipping.
Re: Tranny is out!
Hey get on http://www.svxworldforums.com/ and contact Budfreak. He usually selling 4.44 ratio trannies less than your REM quote. Plus, it would last longer than the normal tranny. Just let him know that dce2005 told you to contact him. Hope this helps you out...
Re: Tranny is out!
Re: Tranny is out!
4.44's actually have weaker clutch packs than SVX transmissions do. They just don't have 100,000 miles of use already pushing around a 3800lb SVX. Rest assured though that they start deteriorating as soon as you put them in an SVX.
My partial remans also perform much better. They shift much faster. There is essentially no realistic comparison between one of my upgraded SVX transmissions and a legacy transmission from a salvage yard. Ask Tom how many times he's installed a salvage yard transmission only to have to take it right back out and exchange it for another. That's part of why he prefers to install one of my transmissions; he knows he only has to do it once. Quote:
Re: Tranny is out!
It's probably also worth noting that shipping is done on my account so you get to pay my highly discounted rates. Last time I shipped to a metro area in GA like Sav. it was $120.
Re: Tranny is out!
before we got one that worked correctly! Since I sourced the transmission I had to do three installs and three removals all in the price that I had originally quoted. If YOU provide the transmission the shop would charge for each install, IF you got a bad one.
Re: Tranny is out!
I thought those jokers ran like $2500 with a core charge?
Eric Rebuilt P/S pump info... http://www.subaru-svx.net/forum/showthread.php?t=50918 If your car wont start info... http://www.subaru-svx.net/forum/show...ighlight=click |
Re: Tranny is out!
Its a partial rebuild he offers for $1000. It includes a new improved high clutch with better friction and a reworked valve body. Pretty much all you need to make the SVX transmission a lot more solid and to last quite a long time.
Re: Tranny is out!
The complete rebuilds are $3,400. The partial rebuilds are only $999. Unless there is hard parts damage (which happens due to poor cooling in about 1 out 5 svx transmissions that go bad) it's always the same parts that go bad. I can replace those clutch packs with upgrades that won't go bad again with a fraction of the labor I have to put into taking every single part of the transmission apart like I do for a full rebuild. I also rework the valve body for fast shifts and higher apply pressures. With a partial rebuild those of limited means can get a bad *** transmission instead of some pos from the salvage yard.
Re: Tranny is out!
It also upgrade the brake band and include a quality remanufactured torque converter.
Re: Tranny is out!
cool..i just checked ecutune.com
Lan, if you do a partial rebuild on a 4.44 do you upgrade the components that are not originally designed for the svx....like the lack of clutches or whatevers different from the 3.54?
Re: Tranny is out!
Excluding the transfer clutch, yes I do.
Re: Tranny is out!
Lan
Do you rebuild the front differential as well as part of your partial rebuild??? Also do you still need cams? Do you take them as trade? Please pm me the details Thanks
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD 92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD 92 Teal SVX LSL lowered with Konig. SOLD 92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone 94 Red SVX L FWDwith LSL Leather Interior. SOLD 92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD 95 Polo Green........With Trany Problem. GONE Almost complete Rear Wheel Bearings Job with Pictures in my locker My Locker http://www.subaru-svx.net/photos/user.php?pearlm30 |
Re: Tranny is out!
No I don't. A front differential definitely counts as hard parts damage. I have and can rebuild them but that's a significant amount extra. I don't do that swapping the whole front dif casting and all and hoping by some miracle it comes out right without redoing the set up thing. I replace the broken parts and set the differential up from scratch. There's no reason to expect the horizontal alignment of the hole the pinion mounts to in the pump to be identical across pumps so it's always better to redo the differential set up if you have the tools and knowledge to do so.
I actually do still need cams because that Jakea guy never shipped me the cams I bought from him and as far as I can tell he hasn't come back to the forums since I last asked him to. |
Thread Tools | |
Display Modes | |
