Old 07-06-2009, 07:57 PM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Strut bad or strut mount?
I've noticed lately when going over small bumpy roads, my car makes a sound as if something is mechanically loose...possibly a mild thud sound. I can't figure it out but I want to say it's the front strut mounts. The car sits normally and suspension-wise feels ok, so I'm hesitant to think it's the struts themselves.
Anyone have this type of problem and can you tell me if a strut mount can be replaced without replacing the strut also?
Please advise
Thanks
1995 Subaru Svx L / AWD
Old 07-06-2009, 08:40 PM
Re: Strut bad or strut mount?
Yes the mounts can be replaced seperately.
Old 07-06-2009, 08:42 PM
NiftySVX NiftySVX is offline
With the age of the car you would likely find both in need of replacement.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 07-06-2009, 11:03 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Is there any way to check the mounts without removing them?
Old 07-07-2009, 05:31 AM
msvx95's Avatar
It's just a phase
Ok second question, can I replace the front strut mounts myself without having to use a spring compression tool or any special tools? If so what is the trick.
Also with Dannmarr's question too, what does a bad strut mount look like?
Old 07-07-2009, 05:37 AM
SVX_MY_BABY's Avatar
You should be able to feel a thud from a broken mount, unless it's just the play from worn out bearings.
If I remember correctly the top mount alone holds the spring so you do need a compressor.
Old 07-07-2009, 07:30 AM
Old Fogey
The strut assembly DEFINITELY needs to come apart to replace the mount, requiring spring compression. There are a number of wear items in the assembly, including bump stop, and rubber cushion. subaruparts.com have lovely exploded diagrams showing the parts in detail. I would be prepared to replace a few other parts if you disassemble your struts, as it's a lot of work to get there. Airtools are a BIG help!!
Glenn
edit: Matt, specific answer to your "bad mount" question is "maybe" you can tell visually if it's shot. A rusty blob that barely holds the spring would be obvious, but a mount that has been in some way compromised by normal wear might not. Hard rubber is involved and may be coming apart invisibly. There was a change in the mount after '93 iirc that "improved" and superseded the earlier part, so your 95 should not be subject to that shortcoming.
Old 07-07-2009, 08:42 AM
msvx95's Avatar
It's just a phase
Ok thanks for the info Glenn. I might as well buy new struts and mounts at this point...ugh.
Old 07-07-2009, 09:07 AM
Old Fogey
Matt,
Depending on rust issues in your locale, that may be the way to go, as struts get tired around 70-80k miles anyway. I'm about to tackle swapping the Koni's from my '93 wreck into the '97 and have a new mount and spring seat in hand to replace the tweeked LF one, as well as front bump-stops, and hope my rust free parts will suffice for the rest of the job. Having done the Koni swap and original install on the '93 I can vouch for their product. I had the original fronts leak and they were covered by Koni warranty, and from what I read here oem stocks are likely to have been lying around for some time.
Glenn
Old 07-07-2009, 09:46 AM
tiv0's Avatar
tiv0 tiv0 is offline
svxless
My front strut mounts went and when i took it to the dealership i was told it would be $300 a piece to have them replaced...
So because i dont have $600 to drop right now, ive been driving around with the broken mounts. The ride is no less comfortable, just annoying from the rattle at every little bump.
I need to get this taken care of as well.
Trevor
Avondale, AZ
1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13
1992 LS-L Claret 178k totaled 10/26/09
1987 BMW 325is
60% of the time it works, every time
Old 07-07-2009, 12:02 PM
Old Fogey
That's because they want to charge you list of $97.82 per mount and $15.32 for the spring seat, per side in front. The labor is probably 1.5 hrs per corner at nearly $100/hr. This is entirely doable by the average hobbyist IF you're CAREFUL!! The spring compressor is borrowable (w/deposit) at most national parts houses, and like I say, with CAREFUL use of hand tools the strut/spring combo can be R&R'ed.
Glenn
Old 07-08-2009, 05:18 AM
msvx95's Avatar
It's just a phase
I hear you...I think that's my problem right now. Car is still driveable though as well.
Old 07-08-2009, 07:09 AM
Originally Posted by RojoRocket View Post
T The labor is probably 1.5 hrs per corner at nearly $100/hr.
Glenn
Labour here is Cdn$80.00 hr at a dealer + 13% tax. Less at most independents. Maybe you guys close to the border should head north for service.
Old 07-08-2009, 08:13 AM
Bad Sway bar end links can sound like bad top mounts too.....just something to check before you buy anything...
Old 07-08-2009, 09:47 AM
msvx95's Avatar
It's just a phase
ok thanks Huck...will check it out...not ready to drop a lot of money yet
