Old 06-30-2009, 02:10 PM
Wolfy's Avatar
Wolfy Wolfy is offline
Send a message via AIM to Wolfy
Arrow wats the best tranny for the 5 spd swap??
some people tell me its the wrx tranny, others say the forester is best and someone even told me a legacy tranny. wats the best tranny for its worth? plus i may need to replace my diferentials as well so am i able to take that out of something too?
Old 06-30-2009, 02:43 PM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
Re: wats the best tranny for the 5 spd swap??
I'm interested in this too.
You'd think the later year WRX ones would be the best after the 6 speed of course, but the Legacys handle the EZ30 well enough so they probably have some durability.
Old 06-30-2009, 02:49 PM
Wolfy's Avatar
i know but someone told me that the wrx trannys can hardly handle a wrx engine. so how can it handle am eg33? i heard foresters have boxer 6 engines but idunno if thats true.
Old 06-30-2009, 03:16 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Originally Posted by STeeL25T View Post
...the Legacys handle the EZ30 well enough...
5 speed EZ30?
Old 06-30-2009, 04:19 PM
I didn't think EZ30 Legacies had an option for a manual.
Also, on a side note: Wolfy, there is an "H" in "what". Not to be a nitpicker, but with all of the questions you ask, I have not seen you spell it correctly once.
Old 06-30-2009, 04:24 PM
The Legacys with a 6 cylinder have not had a manual tranny in them (in the US)
And the Forester has never had a 6 cylinder stock
All Subaru 5 speeds are basically the same, the STi and WRX after 03 (I believe) have a slightly stronger gearset.
The only rear differences are the final drive ratio, and which will be better for you completely rides on what you plan to do with your car....
Drive it, or race it.....
Drive it...any 5-speed will hold up fine...
Race it...no tranny will last forever, just plan on tranny work/replacement...if you want to play, you gotta pay....
Old 06-30-2009, 04:33 PM
Wolfy's Avatar
well i dont plan on racing but i do want it to have the ability to hold its own if i decide to place a lead foot on the gas pedal ok if theres no difference then which is the cheapest and will it have a matching diff?
p.s. whell mike wat hever dho yhou mhean? hi ahlways phut ahn H ihn the right plhace
Old 06-30-2009, 04:59 PM
Gamesy's Avatar
Gamesy Gamesy is offline
you can get a 5spd and just put a 3.9 in the tranny and u can use your stock diff.
personally from what i've heard from friends and known friends who broke wrx 5spds i'd only feel comfortable with a 6spd sti
Old 06-30-2009, 05:07 PM
Wolfy's Avatar
no my diff is almost gone, if i turn at low speeds, its grinds LOUD. i was asking if i pull out a tranny from a subaru, will i be able to take its diff too and use that as a replacement? sorry but wat does 3.9 mean? and wat ratio is mine?
Old 06-30-2009, 05:36 PM
Gamesy's Avatar
the stock gearing in an SVX is a 3.90 ratio some people who end up using the legacy tranny's change it to a 4.44.
you can take the diff too with the tranny but you might have to get a customized driveshaft cause the distance isnt the same and see if you can get a diff where you can stil use your stock axels
Old 06-30-2009, 05:40 PM
the stock gearing in an SVX is a 3.90...
Stock final drive in an AWD SVX is 3.54 not 3.9.
The only 5 spd that will use the stock SVX rear diff is an WRX, their final drive is 3.9 but there is a 1.1:1 ratio on the rear transfer.
Most Legacy/Imp 5 speeds are either 3.9 or 4.11, get the rear diff when you get the trans and follow SVXfiles write up to move your rear LSD into the new rear diff.
redlightningsvx's Avatar
Collision Refinishing Tech
Stock gearing is 3.54
EDIT::Damn..... beat me to it
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 06-30-2009, 05:58 PM
Wolfy's Avatar
wait so if i do swap to a mt then id need to also get a longer driveshaft and a different axle for the new rear diff? sorry if im a bit confused, but say i grab the trans and diff from a junk legacy. i need to replace the axle to match up with the diff?
Old 06-30-2009, 06:05 PM
If you follow SVXfiles write up for the rear diff swap, you'll still have an LSD and use your stock rear axles.
You do need a longer driveshaft though. You can modify some 5 speed leg DS's or get your's stretched (see TomsSVX)
Old 06-30-2009, 06:16 PM
Wolfy's Avatar
i checked out the how to page but it says page cannot be found. weird. i sent a message to tom to see if he can help me out, but he didnt get back to me yet.
