Old 06-22-2009, 03:11 PM
Devilman Devilman is offline
What Air Filter do you use?
I have had the most success with Purolators platinum series (has a metal frame around the outer filter area as opposed to the normal exposed sort. I had recently put in one of the new FRAM washable filters, and my car began stalling and generally not working properly. So i am either going back to the purolator or possibly purchasing one of the green filters from svxturbo. I'm sure someone here has tried one of the green filters, any thoughts?
'92 Silver/black LSL 127K/miles
ponte vedra,Florida (soon to be atlantic beach :P)
Old 06-22-2009, 03:24 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Re: What Air Filter do you use?
I've been using the purolators for years without problems. If you're not doing extensive modding it may not pay to upgrade.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 06-22-2009, 03:30 PM
redlightningsvx's Avatar
Collision Refinishing Tech
I have a green cylinder filter on mine with no troubles.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 06-22-2009, 07:20 PM
NiftySVX NiftySVX is offline
The stock air filter is capable of flowing more air than the throttle bodies. Any modification where the air box is removed will result in a decrease in horsepower due to a loss in volumetric efficiency. Also, air filters which contain oils are dangerous and cause damage to mass air flow meters. I throw K&N air filters in the trash about once a month and put a stock filter back in for a customer who has destroyed their MAF from the inferior filtration.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 06-22-2009, 09:40 PM
Smile Re: What Air Filter do you use?
yeah i wasn't going to go the K&N route...but the green filter from the AZ crew seems popular. Anyhoo, i am going back with purolator premium. Learned my lesson lol.
_matt
Old 06-23-2009, 01:33 AM
Black88GTA's Avatar
Black88GTA Black88GTA is offline
look like a leprechaun to me
Originally had some crap "Spectre" brand cone filter under the hood. God rid of it, and reinstalled stock airbox with Fram Tough Guard filter. There was a noticeable power increase getting rid of my aftermarket hot air intake, too.
Ebony/Gray '92 LS-L, @123k - bought 01/17/2010, parked for 10 years. Getting back on the road.
Old 06-23-2009, 05:24 AM
Green1995SVX's Avatar
Correct.
I use OEM Subaru, by the way.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 06-23-2009, 05:51 AM
dcarrb dcarrb is offline
Whatever Brand-X OEM equivalent is on sale.
dcb
Old 06-23-2009, 08:27 AM
siceclipse's Avatar
siceclipse siceclipse is offline
im using the OEM STi filter my friend gave me off his 2007 Sti limited.
Mike
1992 SVX LS-L Pearl White 102,000 miles (Gone)
2005 Evolution 8 SSL Tarmac Black (new daily)
1995 Eclipse GSX Durango Copper Pearl (teh beast)
276awhp/280awtq @ 18psi (560's inj)
260awhp/260awtq @ 17psi (stock inj)
Old 06-23-2009, 09:58 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Im not familiar with the FRAM washables....but you have to oil those right?? If you use too much oil, it can mist off the the filter and onto the MAF vane... causing your very same symptoms. I would clean your MAF with some MAF cleaner or Brakekleen and use less oil before blowing more cash on another filter.
Old 06-27-2009, 11:50 AM
No it doesnt indicate that it requires oil, like the K&N ones etc. But just putting it in there, it made things go the way of whack. I had the somewhat dirty old one in there for the pinch,ran fine for the moment. Having to content with the humidity jacket that is florida doesnt help either. Purolator here i come.
Old 06-27-2009, 12:32 PM
Hondasucks's Avatar
Subaru Technician
I read on here once about the Perrin filters with the oiled foam layer, that they are supposed to be pretty good. I'm currently just running an OEM Subaru filter in mine. I don't run the cheap aftermarket filters, I've learned I can get 20-30,000 miles out of an OEM filter, and the cheap aftermarket ones are plugged up after like 12k.
1986 VW Jetta
Old 06-27-2009, 12:48 PM
I had used the Perrin filters and gave them a good review in the past. They need more maintenance than any other filter I have used in the past though. Constant getting blocked up with dirt. I now use HKS Mega Flow 200mm elements on my performance engines and a basic Purolator paper filter on stock engines
Old 06-27-2009, 04:36 PM
gbianchi gbianchi is offline
Just a quik comment on those K&N filters, mine had one in there when I bought it and a CEL, read codes, MAF,and knock sensor. Resoldered maf still had CEL, replaced knock sensor. still had CEL, cleaned maf with brake clean, CEL gone replaced K&N with Napa Gold no more CEL, Yippi. The K&N is a good product but if the oiler doesn't do it correctly it can cause the problem. 2 cents............G
03 Baja. 05 Baja turbo
92legacywagon"snow"
94legacywagon"whinny"
84Brat"huey"
92svx"samantha".pearl
92svx"sabastian"4.44 silver
92svx"sabrina".ebony
06 Subaru legacy gt limited.
Old 09-21-2009, 03:42 PM
Just a small tidbit of an update. I had gone back to using purolator paper filter and notice (after the fact and the arrival of some stalling out issues/maf related) that the premium purolator filter in the gold box has oil on it. Upon perusing the store for another brand i revisted the purolator area and noticed that one of the boxes had oil saturation bleeding through the cardboard box, as the plastic bag the ship in was apparently torn. When i installed the purolator gold weeks before that, i didnt even notice this nor is it stated anywhere on the packaging. But it did deposit a film on my MAF that led to stalling/poor performance. Went to NAPA got the gold on sale for $10 and cleaned the MAF with MAF/sensor cleaner. vroom...
Now to adjust my pesky TPS. first time doing that on any car, but from reading here, one of the best car networks btw, I dont think it will be an issue.
-MT
