Old 06-21-2009, 01:18 PM
EmphasisonE's Avatar
EmphasisonE EmphasisonE is offline
Unregistered User
Send a message via AIM to EmphasisonE
Question FWD to an AWD?
Not sure if this question has been asked before on this forum, probably a few times. I'm thinking about purchasing an L model FWD. Its got the woodgrain so at least its not the very base model if I'm correct. I was wondering if it would be possible to convert it to an all-wheel drivetrain. Theres a kit for 5spd. conversion. It would be pretty handy if they had a kit for this...
Old 06-21-2009, 01:35 PM
Re: FWD to an AWD?
Yes it can be done and you don't need anything special. Just need to remove the rear subframe from the FWD and swap in the rear subframe assembly from an AWD car and then I believe also swap the TCU as they are different for FWD and AWD.
There have been a few on this forum that have done the conversion and it seems very straight forward.
Thanks for the correction, Tom.
Old 06-21-2009, 01:38 PM
Re: FWD to an AWD?
yes you will need to swap the full subframe. The FWD lacks components or the ability to mount needed components to run the rear diff. IT is possible, it has been done.
Old 06-21-2009, 06:38 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: FWD to an AWD?
Mine's been converted.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 06-21-2009, 07:03 PM
NeedForSpeed NeedForSpeed is offline
Re: FWD to an AWD?
Did you convert the 3.70 fwd trans to awd? Or did you swap in a 3.545 trans?
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 06-22-2009, 03:26 PM
Re: FWD to an AWD?
No, I blew the high clutch in the FWD trans so I got it swapped to a 4.44 AWD.
Seth
Past subies:
Other toys:
Old 06-22-2009, 07:17 PM
NiftySVX NiftySVX is offline
Re: FWD to an AWD?
I did it back in 2003. I had to custom make some of the wiring, but only the wiring for the FWD switch and the AT OIL TEMP light.
Also, no L model came from the factory with the wood trim. The L model is the only one with vynil instead of ecsaine trim.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
