Old 06-16-2009, 10:34 PM
the_paynter the_paynter is offline
Any interest in a Bolt on SVX turbo kit?
I'm currently designing and (will be building it next week) and bolt on up pipe and down pipe for my SVX.
I will be using a T4 flange because of the turbo I will be using, as well as a 3" v-band down pipe flange.
I was just wondering if there is any interest in these if I decide to build a few.
I could change flanges on the pipes if people wanted. The down pipe will go all the way to the cat back, totally by passing the catalytic converter.
1992 SVX: JDM STI short geared 6-speed swap, COBB short shifter, slotted cross drilled rotors, Smallcar Clear headlight lenses, 1997 Grill.
1992 RHD WRX: EJ20G, 16G, Cusco Coilovers, Wilwood 4pot/2pot brakes, Defi Genome 60mm gauges, Exotic speed downpipe, 3.5" A'PEXi spec GT catback
Old 06-17-2009, 06:23 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Re: Any interest in a Bolt on SVX turbo kit?
<A very similar question.>
Let's hear your hardware specs and price estimate?
Old 06-17-2009, 07:01 AM
Well for the up pipe, I will be using 2" Mandrel bent piping (not sure gauge yet but something thick so it wont crack under pressure.
Im not looking at doing a FULL turbo kit right now, just looking at building the up and down pipes to make turbo installation that much easier on our cars.
As for the price... just parts +labour. I'm not looking to charge people a crazy amount of money for parts just because its for a car that not many people modify
Old 06-17-2009, 08:02 AM
LetItSnow's Avatar
Where are you placing the turbo?
Old 06-17-2009, 08:44 AM
Where the Stock air box and washer bottle go.
Old 06-17-2009, 10:10 AM
LetItSnow's Avatar
Checked in with <Phast SVX> on the good, bad, and tricky for that location?
Old 06-17-2009, 09:55 PM
Gamesy's Avatar
Gamesy Gamesy is offline
your plan gonna be similar to this?
http://www.svx-club.de/Technik/Turbo...r_den_svx.html
Old 06-17-2009, 10:08 PM
the up pipe Idea is generally the same. The location is not. As well my design will have a MUCH larger down pipe, that one looks like it would choke off a turbo VERY badly.
Old 06-18-2009, 12:04 AM
Gamesy's Avatar
downside to that setup is the lack of an itercooler setup
Old 06-18-2009, 09:45 AM
LetItSnow's Avatar
That's perspective. Anyone can correct me, but if using low boost, an intercooler is not necessarily necessary, and not using one can reduce a lot of pipe placement, cutting, and cost. You're talking about a sacrifice in efficiency for sure, but...
Old 06-18-2009, 12:08 PM
Gamesy's Avatar
even if i was running small boost, i'd get at least a small intercooler, have it setup, RAM AIR style
Old 06-19-2009, 05:30 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
Within reason I may be interested. Post your price, or PM it to me if you rather.
'20 Honda Ridgeline
http://www.x35design.com
