Old 05-26-2009, 12:30 PM
NiftySVX NiftySVX is offline
Who will run this 2 minute test for me for comparison?
If you haven't been following the transmission thread I've been having a little bit of an issue. Long story short, I need the voltage measurement at the dropping resistor. I would really appreciate it if someone would take a volt meter and give me a few measurements.
Voltage at the green/yellow wire at the dropping resistor on my car reads about 2.6 volts with closed throttle. I need a volunteer to probe this wire on their car and take this simple measurement. With the ignition on but the engine not running, simply backprobe the green/yellow wire and take the measurement. this can be accomplished with a small metal pin, such as are used for sewing. The reisistor MUST be plugged in. Then, rotate the throttle by hand to full open. This should give a smooth decrease to 0 volts.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 05-27-2009, 10:53 AM
Alright...since there are no volunteers, i'll paypal you 5 bucks...
I need this info asap. If someone would be kind enough to perform this test and pm me the voltage at closed throttle i'll paypal you 5 bucks. All you gotta do is backprobe the dropping resistor...
Old 05-27-2009, 10:55 AM
Re: Who will run this 2 minute test for me for comparison?
I would, but I dont have a multimeter until Friday when Im back at the shop. Sorry.
