Old 05-25-2009, 02:59 PM
Green1995SVX's Avatar
Transmission Pan Gasket?
A simple question.
I'm leaking ATF badly around my Transmission Pan. I believe that when I had the transmission serviced recently, they used an inferior quality pan gasket.
Is there a certain brand of aftermarket gasket that I should be using, or should I buy this item directly from the dealership?
Cheers,
Mike
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 05-25-2009, 03:08 PM
DarknessofDeath's Avatar
Inhabitant of Darkness
Re: Transmission Pan Gasket?
maybe they didn't tighten some of the bolts?
worth a check
Old 05-25-2009, 05:48 PM
I remember changing the internal transmission screen filter and a pan gasket was included. The gasket was folded up in the box with the filter. Needless to say we reused the stock gasket...that one doesn't fold.
Old 05-25-2009, 11:41 PM
I got the screen filter/gasket kit from local advance autoparts store but bought a new OEM gasket. Comes unfolded and is actually rubber unlike the cork junk from the auto parts store.
Old 05-26-2009, 05:34 AM
dcarrb dcarrb is offline
A simple question.
In this instance, you should take it back to the guys who did the service.
dcb
Old 05-26-2009, 06:08 AM
Originally Posted by dcarrb View Post
In this instance, you should take it back to the guys who did the service and bring your gun.
dcb
fixed your post ~
Old 05-26-2009, 07:35 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I dont know why but some dealers like to use that red RTV stuff. I'm not a big fan of gasket maker because it can be a pain to scrape off.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 05-26-2009, 07:42 AM
Originally Posted by DarknessofDeath View Post
fixed your post ~
Oh the irony.
Old 05-26-2009, 08:20 AM
yeah, i know, i'm bored
Old 05-26-2009, 10:23 AM
NiftySVX NiftySVX is offline
There are two gaskets listed at subaru for the 4eat. One is cork and the other is a cardboard like material. I like the cardboard like one better. Also, you have to be careful that the bolt holes in the pan don't get pulled, if they do then the bolts will be tight but the area between the bolt holes won't compress the gasket
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 05-26-2009, 12:25 PM
essveeexxee essveeexxee is offline
10 characters.
Old 06-02-2009, 11:15 PM
10 characters.
Old 06-03-2009, 04:01 AM
ditto
I got a filter/gasket set from rock auto for just a couple of dollars (like $3) and it was the folded paper type. After leaving phone books on the gasket overnight it was flat again.
I have seen mannnnny pans with distorted bolt holes due to overtightening by some 'tard who serviced the pan in the past. Luckily some time with a ball peen hammer will fix the distorted metal and allow for a good seal on the pan again. RTV on the bolts is always a good idea too as it helps seal and keeps them from backing off.
blk 92' LSL w/ average mods
Old 06-03-2009, 08:33 AM
I haven't looked into this any further. I've been very busy at work. I'll post an update when I have it.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 06-04-2009, 06:36 PM
jdmlambo jdmlambo is offline
just finished doing a pan service on my dads svx.. did it myself in my shop. easy since im a mechanic. any pan gasket will do... ive used em all... the torque value is so low (8-10 lbs), and if its overtorqued at all....it will leak for sure.. there is also a torque sequence that should be followed, ensuring even distribution of presure on the gasket.. basically just do it again, but get it done right..
