Old 05-22-2009, 09:42 AM
w261w261 w261w261 is offline
travelling belt finally has stopped
I have downloaded 3 PDF files which I hope can diagnose the problem, but since I am not familiar with the car at all, it will probably be a steep learning curve, so I am tossing this out in the hopes that the solution might "probably" be ______.
The driver's traveler belt has gone dead. Prior to its demise, it would always work when the car was running, I assumed this meant when the voltage was high enough to get past some resistance in a connection, or something like that. Occasionally, when the car was shut off and the door opened, the belt would retract, but only about half the time. Gradually, the belt's ability to retract after the car was turned off lessened, and now it's kaput.
Any educated guesses? Thx.
Old 05-22-2009, 10:40 AM
NiftySVX NiftySVX is offline
Re: travelling belt finally has stopped
Should be a fairly straightforward diagnosis. There was a belt control ecu on the cars with power belts that had the capability of displaying fault codes. I would simply access the plug to the motor with a 12v test light and see if it has power when the belt should operate. You might also try tapping on the motor body, that sometimes makes them work temporarily. If you have power at the connector for the motor then you'll most likely need to replace it.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 05-22-2009, 01:35 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
A quick easy thing to eliminate is the door switch.... turn the selector on the overhead lights to "door" and press the little plunger switch in your doorframe in and out, making sure the light goes on and off consistently. That will first eliminate the easiest part of the system to replace.
Old 05-22-2009, 05:43 PM
suberman suberman is offline
No. But I disconnected the plug from the seat belt motor and connected it to the left rear window switch when mine went out. Now I use the window switch to move the seat belt and that works fine.
Old 05-22-2009, 07:51 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
