Old 04-15-2009, 05:42 PM
SuberNatural SuberNatural is offline
Exclamation engine / trans VIBRATION
Ok, first i will explain what i have done to try and track it down so far.
1. pulled each fuel injector individually to check for a miss. Engine is not missing.
2. replaced a bad trans mount with a Urethane filled mount from YT.
-----obviously made the vibration much worse being that it wasnt the sole cause nor the solution lol. But its been overdue.
3. changed all of the spark plugs with NGK Iridiums.
4. visually inspected all 6 coil pack. No tears, rips, etc anywhere.
Road tested to track down conditions
- driving at highway speed even throttle it isn't super noticeable
-idle is fairly smooth and around 600-650 rpms
-heavy acceleration the vibration is more severe and becomes a droaning noise in the higher RPM's (4k + )
-in park and neutral the vibration is present when revved out of idle. most niticeable around 1.5-2.5k RPMs, but still present 2.5k+ RPMs.
Would like to add that the trans has about 65k miles on it. I have installed an ext filter and a cooler in series with the transmission. ATF recently (about 5k miles ago) changed out. Had front diff fluid inspected (looked good). The trans fluid looks good and smells good (not that i like the smell of hydraulic fluid).
The flexplate has been suggested so far, but I have no real info on anything specific.
Thanks in advance!
_Mike
1992 Liquid Silver/Black LSL
LeveL10 Stage 3 Trans and associated stuff
Old 04-15-2009, 08:07 PM
Re: engine / trans VIBRATION
Anyone have anything on this?
Old 04-15-2009, 08:15 PM
Manarius's Avatar
Manarius Manarius is offline
Engine mounts?
I was thinking driveshaft U-Joint but you said it vibrates even in park.
-Jason
-Obi Wan Kenobi
Old 04-15-2009, 08:22 PM
stiguy's Avatar
stiguy stiguy is offline
you running 85 fuel?
Old 04-15-2009, 08:59 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
any recent exhaust system work?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 04-15-2009, 10:01 PM
kwren's Avatar
kwren kwren is offline
Any codes?
Old 04-15-2009, 11:34 PM
See if the vibration happens when the radiator fans come on.
Old 04-16-2009, 09:40 AM
Vibration is all the time fans on or off.
Engine mounts look to be in good shape and the engine doesn't seem to flop all over.
No codes aside from what came up during testing for a misfire.
No recent exhaust work done to the car. Not since last year when i did the cat gaskets.
I'm trying to sell off my turbo manifold and tunable ecu on my other forum to try and scrape together the cash to get the car to reading, in hopes someone may be able to help me out.
Old 04-18-2009, 08:46 PM
Bump for more help
Old 04-20-2009, 07:31 AM
longassname's Avatar
Just some dude.
I think you need to put it up on the rack where you can stand under it and examine what is going on while a drive makes it be symptomatic.
Old 04-20-2009, 09:31 AM
I'd love to but I don't have any friends with lifts. I have off this week and if I can save some money and sell a few things I may be taking it somewhere.
Old 04-20-2009, 02:32 PM
Just some dude.
Any normal repair shop will put it on the lift for you to diagnose it for free. You don't necessarily have to have them do the work for you--it's part of the quote process.
Old 04-20-2009, 03:42 PM
Billyboy70 Billyboy70 is offline
Hi, When or how did this all start?
Old 04-20-2009, 04:28 PM
Really??? Not around here. Any shop here will charge at least a $15 inspection to check each individual aspect of the car. Granted if you then have that place do the work, they put that $15 towards your bill.
Old 05-12-2009, 10:23 AM
SO i have pretty much come to the conclusion its just the solid trans mount. Anyone want to trade for a good cond. oem mount?
