Old 04-02-2009, 08:35 AM
zavikan zavikan is offline
Keyless Entry option from JDM to USDM?
What would the required parts be?
I am presuming you could rekey the lock to our USDM... then get a blank JDM key (with button) cut to our doors. That way all the locks are the same on the car, and you dont need to get all the locks from a JDM car....
So you would need...
Doorlock/Handle(s), Blank JDM Key, what else?
Also, does only one door have the nifty handle in JDM land, or both? was this only an option in JDM land, or all SVX...
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN!
Old 04-02-2009, 11:44 AM
Re: Keyless Entry option from JDM to USDM?
That is just a start. There is also a module that runs the system. Just the key that is cut for the car is $250. I checked on this when I was buying a JDM car and even with the system in the car, it isn't cheap. I think it will be a much higher price than you are willing to pay. But, I may be wrong.
Old 04-02-2009, 11:52 AM
$250 key?
Thats insane.
$500-$600 range is still in the 'sane' category for me...you think it would go way over that?
Old 04-03-2009, 02:57 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
There is a control module next to the driver seat belt reel.
Only the drivers door handle can be used for keyless entry. That would be on the wrong side of the car for you.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 04-03-2009, 10:26 AM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
True, the JDM door handle with the I/R receiver would only be for the right side, but LHD cars do have the switch in their driver's door handle (to activate the keyhole illumination). I wonder if that would be enough to use the module for the "combination lock" fuction (sans I/R functions)?
Interestingly, the instructions (see copies in oab_au's locker here) also show a picture of a LH door.
Does anyone have the wiring diagrams for the module? I wonder what else it connects to besides the door handle switch and door lock timer module. Does the output from the I/R receiver go essentially straight to the control module, or is the code-learning "smarts" in another module inside the door?.
David C.
