View Poll Results: What's the best option for CV replacement?
oem About $250 3 17.65%
Raxles $139 0 0%
MWE $105 2 11.76%
Advance auto $60 10 58.82%
Replace both front axles at the same time. 4 23.53%
Just replace the busted one (if it ain't broke...) 4 23.53%
Multiple Choice Poll. Voters: 17. You may not vote on this poll
Old 03-31-2009, 01:05 PM
Hop Hop is offline
Classic SVX
CV axle
Hi,
I'm in need of a front CV axle and have been looking at different places to get them and thought that I'd place a poll to get your opinion.
1. oem - about $250
2. Raxles www.raxles.com $139 + core
3. MWE $105 + core
4. Advance auto $60.
The CV joint is ok but the outer boot split on the pass side. Should I consider replacing both front or just the split one?
Old 03-31-2009, 01:12 PM
Re: CV axle
I have used the Advance axles with consistently good results.
Old 04-01-2009, 09:52 PM
NiftySVX NiftySVX is offline
Re: CV axle
If the joint is ok, get a boot kit from subaru and just replace the boot
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 04-01-2009, 10:04 PM
ridered777's Avatar
Finally HAS a 3rd pedal!!
Re: CV axle
Go with the advanced one. I've used them with success.
Always replace both of them at the same time. If you don't the other one will break very shortly after.
-Craig
Old 04-03-2009, 01:10 PM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
Re: CV axle
im on my 3rd rebuild go with OEM
Old 04-04-2009, 12:44 AM
Hop Hop is offline
Classic SVX
Re: CV axle
I went with Advance and got a new CV shaft for $70. It was HARD to get out! The shaft came right out but there were 2 cotter pins that had rusted in place and I spent about 2 hrs hammering and finally drilling the things out. What a hassle.
The CV joint was shot - close to the point of dangerous IMO. I couldn't rotate the outer joint at all. The car was pulling hard to the right and I thought that I also had an alignment issue but all of my issues cleared up with the new axle.
If it weren't for the cotter pins, it would have been a 45 min job.
Does anyone have any tips on getting these rusted cotter pins out for when I attempt doing the other side?
Old 04-04-2009, 02:47 PM
Seraphinwolf's Avatar
Seraphinwolf Seraphinwolf is offline
H6 THE ONLY WAY!
Send a message via AIM to Seraphinwolf Send a message via Yahoo to Seraphinwolf
Re: CV axle
Replace both at the same time. Very least you get dirty once at a time not twice as often. SVXfiles has axles for like $100 shipped with no core charge. Both mine are replaced with these and fitment is perfect and no problems after well over year and probably 20K miles
-Gaddis
94 Bordeux Pearl LSi (Jun 2009) 109k Plate:GADDIS
What they call it a vanity-plate. Shouldn't I be obligated to be vane with it?
Rota Tarmac 3's 18x8" on 245/40/18 Dunlop SP Sport 600's, Perrin light weight crank pulley, PRW radiator, custom coilovers(not GC's), 9006 HID 4300k 50W low beams, DIY garage door lip, and SVXfiles brake kit. Fixxed exhaust so no more sweet sound.
97 White/Black trim Impreza Outback Sport (March 13/08) 150K-180K(sensor broken)Good news is EZ30R and 05' 6speed full powertrain swap is in motion!: Will be doing more work as I can. Gonna be run by a Hydra so yeah fun to be had.
[SIGPIC][/SIGPIC]
-Gaddis
Old 04-04-2009, 03:24 PM
kwren's Avatar
kwren kwren is offline
Re: CV axle
When we can buy a rebuilt for $60-$80 that has a lifetime guarantee why would anyone mess around trying to put a new boot on the old one? Just "change the dang thing"
Keith
Depends on how long the other one has been on the car, but I would always consider replacing both while I was under there with the car up on jackstands, tools handy, me all icky, etc.
I also would always break the axle nut lose before I jacked up the car. I would also drive the pins out the correct direction
Old 04-04-2009, 08:59 PM
SuberNatural SuberNatural is offline
Re: CV axle
Same good results with the advance axle
1992 Liquid Silver/Black LSL
LeveL10 Stage 3 Trans and associated stuff
