Old 03-23-2009, 09:54 PM
Re: Got some things done today... (pictures inside)
90 ft lbs tq is too excess. that tight will warp the rotors which will also cause early bearing failure.
oh well
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 03-23-2009, 10:27 PM
Nevin's Avatar
Nevin Nevin is offline
Originally Posted by Johnybeas View Post
what's the little breather next to the motor hooked up to??
I prefer to vent my valve covers instead of feeding their oil vapors into the intake. What you see there is a small filter.
Jesus is the remedy
2015 Expedition EL Ecoboost
Old 03-23-2009, 10:31 PM
Nevin's Avatar
oh well
I've heard people talk about warped rotors, but I've never seen it in person, and I've not seen it all, but I'm defnitely not new at cars. The way I see it, a stud would break long before a simple nut would have the capacity to bend a piece of metal that's already sandwiched in between to other pieces.
I understand what you're saying, but from what I know (5+ years of working at a tire shop) +4lb. ft is not overkill espescially considering it's a 17" wheel instead of a 16" which means more of a gyroscope effect on the hub assembly, etc...
Jesus is the remedy
Old 03-23-2009, 10:47 PM
Banned
interesting..... lol
Old 03-23-2009, 10:57 PM
Nevin's Avatar
It just keeps oil and grime from building up in your intake. These subarus have an interesting oil separator device in the top of the valve cover anyway, so they're not as bad as some cars which can get pretty sludgy in the intake though. But every little bit helps.
Jesus is the remedy
Old 03-24-2009, 09:36 AM
SuberNatural SuberNatural is offline
What did you do with the rubber line?
1992 Liquid Silver/Black LSL
LeveL10 Stage 3 Trans and associated stuff
Old 03-24-2009, 11:25 AM
Nevin's Avatar
Well, when I made the intake, I only made fittings for the two TB idle control lines, and just decided to leave the rest out for this reason actually. Now both sides just vent, and the intake stays nice and clean.
Also, bheinen74 please don't take my replies the wrong way, I'm not trying to criticize you or what you're saying. On the stock wheels I normally do only go 85 lb./ft. but honestly in all the years I've worked on cars and the thousands of tires that I've changed, I have YET to see a bearing failure or warped rotor happen because of over-tightening a lug nut. I know some have talked about it, but to me it's just a mythical creature that I have yet to see firsthand.
Jesus is the remedy
Old 03-24-2009, 11:30 AM
Nevin,
I torque my lugs to 95 lb/ft.
Old 03-24-2009, 11:36 AM
Nevin's Avatar
Nevin,
Thank you! lol
Jesus is the remedy
Old 03-24-2009, 12:03 PM
kwren's Avatar
kwren kwren is offline
Thank you! lol
I am with you!
Things have to make sense...
Keith
Old 03-24-2009, 01:03 PM
http://www.subaru-svx.net/photos/files/How-To/28201.pdf
see this last paragraph\then tell me you are not over the torque limit
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 03-24-2009, 01:17 PM
kwren's Avatar
Can anyone give any logic to this being relevant to wheel bearing failure? Of course, I would always go for installing the lug nuts by hand and turning them all the way up with my fingers. Torquing them and then after a few miles re-checking them.
I would love to learn exactly how the bearings could be affected in their location by the lug nuts in their location.
Keith
Old 03-24-2009, 01:23 PM
because, simple. overtightened lug nuts, will warp the rotor, and the hub housing will get more stress, which will make bearings fail.
same reason the heads get torqued to spec and not more. i dunno, i am not willing to argue on facts
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
