Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Interior Mods
Old 03-06-2009, 07:21 AM
processengr's Avatar
Question Question:how to realign ashtray in console
My ashtray lid is mis-aligned in my daughter's '92. Quick inspection didn't show any exposed screws to loosen...anyone else run into this?
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 03-06-2009, 11:20 AM
Manarius's Avatar
Manarius Manarius is offline
Re: Question:how to realign ashtray in console
It just pops out...just pop it out and push it back in.
-Jason
-Obi Wan Kenobi
Old 03-06-2009, 11:33 AM
i want to know what's plugged into the cigarette lighter.
Old 03-06-2009, 12:15 PM
I have had the ashtray out,(many times!) and tried shimming the unit to get it to sit straight, but it is still out of alignment. I couldn't find any adjustment in the area it fits into, although there are some screws behind the ashtray.. I have a digital voltmeter plugged into the cigarette lighter. Bought the plug-in voltmeter after reading SVXCESS's alternator and wiring upgrade threads. Bought the green Cyberdyne unit, not as nice as the Nordstrom that he has.
Cheers! Gordon
2018 Tesla M3 30k
Old 03-06-2009, 01:05 PM
Gordon,
Check to be sure the door isnt cracked around the hinge/pins on each side. Additionally, any disassembly/reassembly of that dash could throw it off. I would think the console/dash supports under the "comma-shaped" plastic panels could perhaps be missing screws.
Old 03-10-2009, 12:01 AM
subbieatnz's Avatar
My ashtray lid and radio door are out of alignment. so is other bits on my dash. it annoys me abit
1989 Vortex 6 Maroon
1983 RX Silver Grey
Old 03-10-2009, 12:50 AM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
Provided that the problem isn't that your whole dash is out of whack, you can fix the radio door by nudging either side of the cage up or down a tiny bit. Slightly loosen the two upper screws that hold the cage into the dash while you make the adjustments, and then tighten them after you're done.
David C.
Old 03-13-2009, 02:15 PM
It's Just Eric's Avatar
Missing in action
ditto for the three screws per side underneath the comma shaped plastic covers n the sides below the dash. pop them off, loosted the passenger side a bit, make necicarry adjustments, and tighten them back
R.I.P Cool Signature.
Old 04-07-2009, 08:34 AM
zavikan zavikan is offline
that will solve half his problem anyway... his whole dash is tweaked. Look at the lighter too. As well as the center console. The center console doesnt line up at all laterally on the drivers side.
Yes, realign the radio cage (though your pic doesnt show the line between it and the climate control systems, hopefully that line is out of wack too, and this will fix that. If the upper line ISN'T out of align...well, leave the door alone.)
I would work on tweaking the center console back to center first.
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN!
Old 04-07-2009, 08:53 AM
CorSVXette's Avatar
Classic SVX
Yea, I will say the radio door. Mine is also out of alignment since I was over at Tom's for some work. He pulled it out for one reason or another. No biggie Tom. I knew it was just an adjustment and I was going to have it readjusted when I came down for the radiator. Now that I see how it is adjusted, I may do it myself if I get the time. Anyway, see you soon. I'll let you know.
Paul
1969 Corvette
1995 Corolla
2003 Highlander
Old 04-07-2009, 09:46 AM
Jefus Jefus is offline
Jeff Williams
Send a message via AIM to Jefus
Im glad someone else noticed that whole dash is off. If you look just to the left of the cig.plug you will see the divers side is not even close. and that the ash tray is in line with the "comma" cig. plug section and that it seams that they are all off somehow.
Old 04-07-2009, 10:36 AM
Hi all!
Just a follow-up...thanks to Mike and others, I was able to get the alignment better, although it is still not perfect...root cause is the 1/8" longer than stock stereo I had installed (VR3 500BT) I had to drill out the spot welds in the radio cage to remove back panel of cage to let it fit. When I tightened up the new radio assembly, it caused the misalignment...
Cheers! Gordon
2018 Tesla M3 30k
