Old 01-12-2009, 12:00 PM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
possible front diff problem
Ive been having a noise that occurs when making turns at slow speeds 0-20mph . its sort of like a creaking click,click, click. I wasnt worried about it origionally because it hasnt been affecting the driving or making the car buck at all. Could this be my front diff going out or something else? also how do I check my front diff fluid?
[SIGPIC][/SIGPIC]
Old 01-12-2009, 12:42 PM
Re: possible front diff problem
There is a dipstick for the front diffy, Looking from the front of the car it is on the left side of the diff... The dipstick sits pretty much right on top of the differential
Old 01-12-2009, 12:53 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
I had that symptom when the front 1/2 axles went bad. Might check for torn rubber boots or leaking.
Gene
Gene and Ben
Old 01-12-2009, 01:32 PM
jman050's Avatar
Its a Classic!
id be relieved if it was that and i didnt have to replace the tranny
[SIGPIC][/SIGPIC]
Old 01-12-2009, 01:39 PM
Wikedjuggalo's Avatar
Rebuilding
You know when your front diff is going out when you are driving and you hear a faint sound that turns into what I could only describe as "a baseball card hitting a spoke (card in a bicycle wheel)". You can feel the vibration in the Selector knob.
Old 01-12-2009, 05:22 PM
jman050's Avatar
Its a Classic!
now this worries me because this is exactly what it sounds like but from what ive read could also be cv joints or axles. doesnt the car buck when the front diff is starting to go??
[SIGPIC][/SIGPIC]
Old 01-12-2009, 05:27 PM
jman050's Avatar
Its a Classic!
I dont know if it helps but it happens alot more often during right hand turns than left hand turns
[SIGPIC][/SIGPIC]
Old 01-12-2009, 05:42 PM
bwb3's Avatar
I bought an SVX with a bad front diff and it was a nasty clunking sound going in a straight line. My first SVX had more of a clicking sound when turning hard. I don't recall the direction but turning one way identified the driver's side. As recommended, I went ahead and replaced both front 1/2 axles.
Gene
Gene and Ben
Old 01-12-2009, 06:11 PM
Rebuilding
If its stright line driving then its the diff, if its only when turning probably not. Could be CV joints. The "bucking" only occurs after the pinnion bearing (I believe that is what it is called) is shot
