Old 01-12-2009, 11:08 AM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
Unhappy sunroof drain tubes, AC, Emergency brake problem
Hey guys I havent been on the forum for a couple months and my car is needing some TLC and maintenance.
Ive come to the conclusion that it is indeed one of the sunroof drain tubes that is causing the buildup of water under my passenger seat. Does anyone know which drain tube this would be and how i would access it?
Also My emergency brake light comes on when the temperature is below 60 degrees F or so and stays on irrelevant of the actual brake. is there a sensor or something that could be causing this?
and finally my AC periodically would stop working a few months ago and has finally went out completely. The compressor works and the fan motor still blows air. I was told there could be a filter in the system that could be clogged. any more info on how to diagnose this would be appreciated.
Thanks in advance
-jason
[SIGPIC][/SIGPIC]
Old 01-12-2009, 11:15 AM
Green1995SVX's Avatar
Re: sunroof drain tubes, AC, Emergency brake problem
Jason-
This is caused by your brake fluid being ever-so-slightly low. When it's cold out, the fluid shrinks in volume and trips the sensor. Simply top up your brake booster with brake fluid. (Should only take a few drops.)
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 01-12-2009, 11:35 AM
jman050's Avatar
Its a Classic!
awsome thank you! im glad atleast one of my problems is an easy fix
[SIGPIC][/SIGPIC]
Old 01-12-2009, 11:55 AM
taylorbr's Avatar
taylorbr taylorbr is offline
Jason-
This can also be caused by your e-brake switch remaining stuck because it is cold. In that case nothing is wrong, but the light will remain lit until the car warms up enough. This occurs in my Legacy and I have chosen to ignore it...
'93 Legacy LS (will last longer than the cockroaches)
'94 SVX LSi
Old 01-12-2009, 01:02 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Note the 4 front and rear locations of the drains. I've never done it but you may have to pop some trim panels off to see if one came unhooked or is clogged.
Gene
Gene and Ben
Old 01-12-2009, 04:25 PM
redlightningsvx's Avatar
Collision Refinishing Tech
I had the same water leakage into the inside of my car. The problem was that the drain was pointing towards the pedels instead of down at the ground. Just remove the pass. side kick panel then pull out the bundle of wire from the access hole and you will see a yellowish/clear tube which is your culprit. To see if it's clogged just run water over the roof with the sunroof cracked enough so water can go into the drain, then look at the tube for water coming out.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
