Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Interior Mods
Old 01-08-2009, 08:19 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: Custom gauge install
Here's some pics with the other gauges on.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 01-08-2009, 08:24 PM
These gauges seem taller than normal because they are placed exactly where LetItSnow has his and they hit the plastic. They seemed about 2-3/8 taller so I had to cut the hole big enought to fit the whole gauge bezel and recess it lower so it would fit.
Seth
Past subies:
Other toys:
Old 01-08-2009, 08:31 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
The larger diameter makes it challenging, mostly because the two top holes are so ridiculously small. The only way to make them look 100% natural by size is to replace them with smaller, mechanical gauges, and none available have any sort of style match. I don't find it offensive.
Old 01-09-2009, 06:42 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Fit or not, they still look amazing.. I'd like to know how hard it is to wire those things in also. That is, if you wouldn't mind being descriptive..
Old 01-09-2009, 05:03 PM
I'm hoping to start the wiring soon as my dash is apart and the gauge lights are a little bright without the bezel in front of them. I'm going to try to relocate the FWD light also. Right now I cut out a space in the dummy light bar and put in the FWD Faceplate which was removed when I added the new gauge in the empty space to the right of the STEERING light.
Seth
Past subies:
Other toys:
Old 01-09-2009, 10:42 PM
Quick question. For my trans sending unit I'm going to drill and tap a hole in my perma-cool filter mount. When it's tapped will the sender get a good ground from that and will it leak do to not being able to teflon tape it?
Seth
Past subies:
Other toys:
Old 01-12-2009, 07:34 PM
UPDATE: I got the sending unit wiring for the water temp done and both grounds for both gauges done. All I need to do now is look over my FSM and find a suitable power and dimmer wire to hook up to (probably the cluster buttons) and then drill/tap a hole in my perma-cool filter mount for the other sending unit and run the wire for it. Then i'm done. I'll try to take some pics of where my wires are tomorrow.
Seth
Past subies:
Other toys:
Old 01-14-2009, 05:08 PM
I got my Coolant temp gauge up and running so now all I need to do is drill/tap the tranny filter mount.
Seth
Past subies:
Other toys:
Old 01-19-2009, 04:32 PM
I'm Stuck still on the wiring for the power. I looked at my FSM and seen there is 2 wires going from the fuse box to the ignition switch but I can't seem to find them. Any Idea where exactly under the fuse box their located? Thanks
Seth
Past subies:
Other toys:
Old 01-19-2009, 09:32 PM
svxash's Avatar
svxash svxash is offline
Those temps seem high.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
Old 01-19-2009, 10:18 PM
Yea the gauge is off a lot whenever I turn on any accessory. It needs rewired hence my question above.
Seth
Past subies:
Other toys:
Old 01-24-2009, 04:49 PM
Well I emailed cyberdyne and told them my situation and they said leave a phone # so they can further assist me. I think they have no clue because I told them everything in detail. Also both of the f@#kin gauges cracked along the face because it got to hot in the speedo cluster. So i'm now thinking of just getting a non-digital, accurate gauge and mounting them in a pillar pod
Seth
Past subies:
Other toys:
Old 01-29-2009, 01:18 AM
jcimos's Avatar
jcimos jcimos is offline
Sorry to hear that it didn't work out. I was hoping for the fully functional final setup.
Old 01-29-2009, 03:57 PM
yea I hoped for it to work to. Cyberdyne did e-mail me and said it was a bad ground which is bs because it was grounded directly to the engine block.
Seth
Past subies:
Other toys:
Old 01-29-2009, 04:50 PM
LetItSnow's Avatar
If you're considering other gauges, what kind?
