No (Ka'pasch) from gas tank?
I'm sure it's probably nothing but I have to ask, is the car not releasing pressure when you unscrew the gas cap normal? (low full or otherwise).
Every car I've ever had when filling for gas and unscrewing the gas cap has given me that Kapasch gas depressurizing sound... should I be looking for something or just write it off as simply pure paranoia in my mind?
1994 subaru svx le 112k |
Re: No (Ka'pasch) from gas tank?
I didn't think the gas cap did it when the tank was full.
However, this may mean that your gas cap isn't holding pressure and needs to be replaced.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
I always hear the pressure difference on my '92. I have a recollection that back under warranty my gas cap was replaced as an unofficial factory recall because it wasn't holding pressure.
Hearing that sounds depends on many variables such as temperature, amount of gas in tank, etc. Sometimes I hear it and sometimes not. I wouldn't freak out just yet, based on that alone.
Jerry 2005 Baja Turbo 2008 Ford Crown Victoria Police Interceptor jnj7707@yahoo.com |
Thanks for the feedback!
[hijack]
sorry to hijack, but i had a gas cap problem where i started to open it and heard more pressure than normal, so i proceeded to open it slowly and the pressure wasnt dissappating and when i finally had the cap unscrewed all the way, gas shot out of the tank really bizzare my only explanation would be that the temp was warm/hot when i filled up and then when i opened it later that the temp was much cooler, but theres no way that was the case. temps during those times were very similar ?? [/hijack]
Trevor Avondale, AZ 1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13 1992 LS-L Claret 178k totaled 10/26/09 1987 BMW 325is 60% of the time it works, every time |
