Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Brake Upgrades
Old 05-11-2008, 10:24 PM
Nevin's Avatar
Nevin Nevin is offline
Yeah, mine does dive quite a bit. My next project is to freshen up the suspension. Well...after I get the 4.11 tranny in.
Can we run DOT4 in our systems? I'm sure that wouldn't hurt either (if it's compatible) but either way, I really should go through and flush my brakes and get some new fluid in there. Getting the old crap out of the lines usually does wonders too.
Jesus is the remedy
2015 Expedition EL Ecoboost
Old 05-19-2008, 11:22 PM
svxstarship svxstarship is offline
These work great...
Great feel and fade resistance.
1999 Audi A8. No more SVX's for now.
Old 06-01-2008, 10:42 PM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
How much did the Movit kit cost and is it still available?
-Dustin
Old 06-03-2008, 04:50 PM
Yes it's still available from Germany. 2500.00 approx, and a long wait to get it.
Of course I might be selling my 96 soon, so just buy the car a get the brakes to
Rotors are 308mm diameter and 32mm thickness. There is more info on their website.
Old 06-03-2008, 06:23 PM
lechnoid's Avatar
lechnoid lechnoid is offline
Tech & Almost Lawyer
Another little add-on to a firmer setup that gets used (harshly) quite a bit is higher-temp fluid. While it adds no real benefit from standard DOT 3,4,5....the life will be longer. This only works if you're getting your brake temps up regularly or even irregularly but with large spikes. I used ATE Super Blue in my VR-4 after I had upgraded the rest of the brakes. I was tracking the car frequently and was replacing/flushing almost as frequently. After changing fluids, I found my braking life held up much better to high temps.
I was also on the pit crew for Steve Gingris in 2004 at the Trespassers Wil event (SCCA Club Rally Nationals). He also used Super Blue.
Old 06-04-2008, 08:10 AM
On brake change, which pads do you use? Shall you always order them from Germany?
Old 06-06-2008, 11:34 AM
I am pretty sure the caliper is the same as a Porsche caliper ( maybe a boxter) it looks similar. I wouldn't be suprised if some other pad application would fit. If not, I would get them from Germany. But I hardly drive the car so I'm not to worried.
Old 06-06-2008, 12:55 PM
Did you try to ask them?
Old 08-04-2008, 04:11 AM
Re: More brakes......
Wow, I did email Movit concerning their kits, here was their reply:
""dear danny,
we can offer you following brake kits for your car:
front:
304x32mm with 4-piston caliper @ € 1800,00 net.
322x32mm with 4-piston caliper @ € 2100,00 net.
342x34mm with 4-piston caliper @ € 2650,00 net.
342x34mm with 6-piston "BILLET" calipers €3400,00 net.
if you need any further information please let me know.
mit freundlichen grüßen,
with kind regards,
cordialement,
hussien chahrour
MOV´IT GmbH
rennwiese 4
77855 achern
h.chahrour@movit.de
www.movit.de
HRB 220791
amtsgericht mannheim
fon: +49 7841 681230
fax: +49 7841 681231
geschäftsführer: guido frensemeyer
PS: Zur schnellstmöglichen Bearbeitung der Anfrage senden Sie bitte immer den vorangegangenen Schriftverkehr mit.
Please quote all previous messages when sending replies to help us to provide better and faster service.""
OUCH!!!
