Old 03-16-2008, 11:15 PM
snofrek's Avatar
snofrek snofrek is offline
SubyFREAK
Send a message via MSN to snofrek
Question Question about the kick-down solenoid?
OK im putting in a 4.44 tranny into my car and i have a question about the kick-down solenoid... what is it, i mean i know what it does, but what is it physicaly? and would it be possible to wire a potentiometer into it so i could adjust it from inside the car? say turn it down to kick-down real easy for racing, and turn it up to kick-down less for highway and hill climbing? it would be cool if i could but if not.....
Old 03-17-2008, 03:36 AM
Greetings Tom,
There is no such thing. The TPS (Throttle Position Sensor) provides the initial signal to to the ECU (Engine Control Unit) and the TCU (Transmission Control Unit). If you are going to go racing you have a selector to play with. Does not the OEM kick down work real easy.
Old 03-17-2008, 04:36 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
I think some older autos had a switch (not a solenoid) under the pedal, but the SVX doesn't.
The gear is selected on the basis of Throttle and Speed. The best way to adjust it is by reprogramming the chip in the TCU. But nobody knows how to do that yet. Unless you're a computer geek then you're out of luck.
Another option would be to try and fool the system by putting a potentiometer between the TPS and the TCU. So it thinks the thottle is more or less open than it really is. But to be honest you are probably going create a whole load of drivability issues.
Just install a power mode switch and you will be happy enough.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 03-17-2008, 04:49 PM
snofrek's Avatar
SubyFREAK
Originally Posted by Trevor View Post
Greetings Tom,
ok cool, i was just wondering what it all was and such, i know about the selector, except right now i cant use it cuz it dont work cuz of the tranny problem im having. But i am putting in the 4.44 next weekend and cant wait to have the benifit of a fully functional tranny!!! thanks trevor and b3lha for the info!!!
Old 03-17-2008, 07:28 PM
Tom, the thanks are appreciated.
