air compressor
does an air compressor posses enough air to give me any psi?? could i use it like a shot of nos...??
Fixed it
You would need to shoot it out of a scuba tank directly into the mixing tunnel with software to manage the timing and fuel... that said you will not see too much improvement.... just use no2 to achieve REAL results with FAR less effort.
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? Last edited by Speedklix; 12-17-2007 at 06:58 AM. |
A compressor? Like the $10 kind you use to fill your tire when it's low? Not a chance. If, as Speedklix suggested, you used a SCUBA tank to fire a massive rapid blast of air into the intake, I'm betting the car would just stall. The software wouldn't be able to adapt quickly enough and you would run hugely lean, and stall.
1992 SVX LS-L #1222 Pearl White 1987 GL Turbo wagon, 5 lug conversion, D/R 5 speed (Rice killer) 1992 Dodge Ram 4x4 diesel (car hauler) 1968 Dodge Polara convertible (Camaro killer) 1990 Toyota Corolla FWD auto (330,000 mile grocery getter) 1986 VW Jetta |
Which is why it would have to be placed way in there to see any benefit.
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? |
